Car Audio & Video Logo
Question about Car Audio & Video
I bought a 1997 Honda Accord for my daughter. I noticed that the right front door speaker wasn't working. And since the cd player didn't work at all, I bought a new Pioneer deck and put it in, connecting all wiring to a new harness that would plug into the Honda harness. Well, the right front speaker still did not work. I took off the door panel and got to the speaker, unplugged and plugged back the wiring connector to the speaker over and over, but still no sound, not even a pop or crackle. What should I do now? Thanks.
Posted by kces9395 on
kenw392
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Car Audio & ... Master
  • 2,226 Answers
You'll probably need to replace the speaker.
Posted on Jan 25, 2011
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
1helpful
2answers
I have a 1999 Honda Accord with a CD radio with no extenal speaker connection. I have a new XM radio and want to connect the radio to the speaker system. How do I find the place to acces the cars...
Hello! Pull the radio...There is a connector with the following speaker wire colors...
Front driver door + Red/Green
Front driver door - Brown/Black
Front pass. door +Blue/Green
Front pass. door -Gray/Black
Left rear+ Blue/Yellow
Left rear - Gray/White
Right rear + Red/Yellow
Right rear - Brown/White
If the vehicle is an EX the left and right Tweeter's are the same as the Front drivers/Passenger door speakers and merely connect to them...
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Replace a door speaker in a 1997 honda accord sedan
It's pretty easy to do. First, get a pry tool from a parts store to aid in getting the door handle off. While you are there, get a pry tool to aid in getting the clips off from around the outside of the interior door panel. Take those items off, unscrew the door arm rest screws and you're golden. unscrew the existing speaker, match the size with a new one, hook up your wiring, test the speaker by turning on the power and playing the radio and once you confirm you have a working speaker, put it all back together.
I dont know what gos to what
Radio 12V- white/yellow
Radio Ground black
Radio Ignition yellow/red
Left Front Speaker (+/-) blue/green - gray/black
Right Front Speaker (+/-) red/green - brown/black
Left Rear Speaker (+/-) blue/yellow - gray/white
Right Rear Speaker (+/-) red/yellow - brown/white
I purchased a 1997 Honda accord Se for my 16 year old daughter but the radio/cassette doesn't work. I want to put in a cd player without paying a fortune, what is my best option?
i would recommend purchase an aftermarket cd player. you can also purchase a cd player is dash kit. that will come with the wire harness connector and the brackets to hold it in place.
Speaker wire diagram
Constant 12V+ White/Yellow
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger Yellow/White
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
1helpful
2answers
2004 honda accord CD player not working
I have the same problem I bought one with the same problem. Does any one have a solution.
Help
2helpful
2answers
Japanese import integra type r stereo wiring diagram
Try the following, this is an 1997 USA Integra
Radio Constant Wire 12V+: Blue/White
Radio Switched Wire 12V+: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Left Rear
Front Speakers Size and Location: 5 1/4′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Front Speakers Size and Location: 6 1/2′ Side Panels
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
