Question about Sansui DTV2760 27" TV
On some stations a solid black square covers the picture. What could be causing that?
Posted by joann_wolski on
Anonymous
    New Friend:
    Problem Solver:
  • 10 Answers
If its a hd setup programming not broadcast in HD but viewed on a HD channel will be letterboxed of sorts
Posted on Jan 24, 2011
How do I get the black square off channel 5 CBS Phoenix? It covers the middle of the screen
to me it sounds like you have the CC turned on.. Closed Caption setting..
Sep 21, 2014 | Televison & Video
Have a black box in the top left corner of tv how can I get
check and see if your tv has PIP (picture in Picture) which you turn on and off with the remote. If you do you have PIP turned on, but not set to any station.
Nov 30, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Big Black Square
It turns out that the Closed Caption option was turned on somehow. When I turned that off the Black Square went a way and did not return.
Sep 14, 2008 | RCA T19408 19 in. TV/VCR Combo
Picture trouble
Good Day, britt93;
It sounds like you have the TV's CLOSE CAPTION on; in the text mode, turn off and you and the TV will be fine.
Good Luck, big IRISH.
Aug 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Lp70+ display shows a solid black vertical line
the light tunnel is either collapsing and blocking the light going through it (and needs replacement) or the vertical/hoizontal adjustment of the tunnel. if you take the lamp out and move the colorwheel (with a pencil eraser) to the clear section, you should be able to see a square through it. if part of the square is blocking the middle, the tunnel needs replacing.
by the way, on some projectors the light tunnel is called an integrator rod.
Jun 17, 2008 | InFocus LP70+ Multimedia Projector
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Black square covers the center of the screen-
the closed caption is probably on. look on your remote or in the tv menu for cctv and change the setting. there are at least four different types of cctv and you may have to cycle around some to find "off.
Apr 29, 2008 | Toshiba MV19N2 19 in. TV/VCR Combo
Black square
hmmm...the black square syndrome..sounds like the picture in picture settings are unhappy..check those, to see if maybe it's on some sort of timer, and accessing a non channel(which might explain the black square).
Feb 29, 2008 | Hitachi 57F500 57" Rear Projection...
Picture problem on certain stations
I seen this problem. On my tv the text caption was on. Check your caption mode, turn off see if problem goes away.
Jul 02, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Tv picture
Your closed captions are on and set to TEXT. Go into the menu, turn off the closed captions and the black box will vanish.
May 22, 2007 | Zenith SY2768S TV
Sansui DTV2760 27" TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
