Samsung CLX 3160fn All-In-One Printer Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have vertical lines that are missing the black toner on everything i print, the lines are always in the same place so i assume it has something to do with the transfer of black toner in those spots. the black sometimes shows up faint
Stephen Lam
Level 3:
President:
  • Master 670 Answers
  • Posted on Feb 07, 2011
Stephen Lam
Master
Level 3:
President:
Answers
670
Questions
Helped
252069
Points
2115
If your printer prints with faded bands similar to this:i have vertical lines that - slamfix_29.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
My hp laser jet printer p1606dn is printing vertical lines n the left of the document and its missing all the left side of the doc
From this limited information, I suggest you remove the toner cartridge and tip it left to right several times to re-disperse toner. Put it back in place and try printing again. If the doesn't work, your toner is likely low or empty.
1helpful
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
4helpful
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
2helpful
Vertical blank "line" on printed material.
try the toner cartridge. You can see where its coming from by printing 1 page. When the page starts coming out of the machine open the cover. Take out the toner cartridge and look at the page. The line should be there and you should be able to figure whats causing it. It's almost always the toner cartridge. If you have an old cartridge put it in and run a test with it. If the line is gone its the cartridge. Steven 818-888-0006
4 faint lines running vertically down the sheets of paper
just open the printer cover and clean the toner with tissue paper and make sure the toner is not damage othewise you have to replace the toner.
1helpful
HP 3050 vertical black lines during fax
OK, from the desciption i can assume several things here are some option.
If by receipt you are talking about the confirmation the unit prints the the problem is likely dirty glass.
You would also get the lines when you make a copy using the ADF.
Open the lid there are two areas of glass the thin strip is likely dirty and needs to be cleaned.
If by receipt you mean pages you receive from someone else, and not printed or copied on your machine, then their machine has the condition described above.
If everything has the lines then you have a toner or fuser problem:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
2answers
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Not printing 9
Does it print something in place of the 9 or does it do nothing at all? If it prints 2 vertical lines the printwheel is bad, if nothing at all happens at the least you need the keyboard contacts cleaned.
DickyO
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
