Flooding which occurred three years ago could not possibly still affect speaker wires. Have you checked all the connections? Did any of the speakers themselves get wet? Still, if you want to get new speaker wire, just take a short piece from the existing wire to a good electronics place to make sure and match the impedence. They're not "called" anything except speaker wire.
SOURCE: Jensen XA4100
try using power directly from main to the remote terminal to see if headunit has a problem or the amp.please disconnect remote from head first.
SOURCE: Need A Wiring Diagram
Hi Matt,
I assume you have probably got the answer but just in case you haven't. I just opened the box on a unit someone gave me and I have the harness. From left to right the first pair (top and bottom) are the left speaker + top and left speaker - bottom. The next two are the right speaker. The next two are left signal in and the last pair are right signal in.
I'm looking for an instruction manual if there even is one.
Brian
SOURCE: Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
SOURCE: Jensen JPA285 425 Watts 2-Channel Amplifier instalation
Yes, watch out for bad wiring! My father's 73 chevy caprice caught fire because of an amp that was wired in poorly. If you have a multimeter it shouldn't be too hard to find each speaker wire, as the speaker will show up with a certain impedance, Like 4 ohms of 8 ohms. Wiring it in phase is the real trick. For that you can only hope there is some sort of color code that the car came with, and there is a pretty good chance there is. I am assuming you are looking at the chopped radio wiring harness. There might be something like brown with a white stripe, and white with a brown stripe. It could also just be brown, and brown with a white stripe. You get the idea. They should all be wired in the same pattern, If they did not do this, then the some car manufactures just have better standards. I believe you can take a AAA battery and hit the two wires you know to be one speaker, and you should hear a pop from that speaker. I would be careful doing that if the speakers are really old, but it should be safe even then.
Its amazing what a 15 dollar multimeter can do in everyday electronics. My friend and I built an electric motorcycle, and obviously its very crucial for that, but I have used it for tons of things besides that. Especially old car wiring.
SOURCE: Hi! I have a Jensen XA2150
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
