Cell Phones Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you turn the ringer off on KX- tg4011 serries telephone?
Anonymous
Level 3:
  • Master 492 Answers
  • Posted on Jan 24, 2011
Anonymous
Master
Level 3:
Answers
492
Questions
Helped
142828
Points
1567
Some phones, like the iPhone, have switches that will turn your phone on vibrate. If it doesn't have anything like this, go into the Settings, look for your Sound Profiles and turn the ringer volume down. This will make it so you don't hear anything when receiving a phone call though, so you'll want to turn the vibrate function on if possible.
Manual for Panasonic KX-TGD 530
Duplicate question Deleted. Refresh page to see it published.
KX-TGD530
Panasonic https://help.na.panasonic.com > telephones > kx-tgd530
Model includes: 1 Cordless handset base unit. Base unit part # KX-TGD530, handset part # KX-TGDA50. Shop Panasonic. Operational Inquiries.
Operating Instructions
Panasonic https://help.panasonic.ca > ALL > KX-TGD510
Feb 22, 2018 - Press MDN or MCN repeatedly while ringing. R To turn the ringer off, press MCN repeatedly. Base unit*1. *1 KX-TGD530 series. Press ...
52 pages People also a
How do I get my older Panasonic hand set phone to ring on an incoming call?
The KX-TGA401C handset works with the KX-TG401x, KX-TG403X and KX-TG651x phone systems among others. If you have the appropriate base, see the suggestions below.
Does your handset read Ringer Off? Try setting the ringer volume. With the phone system in standby (no calls in or out for any handset), press Menu. Navigate using the Up/Down arrows to Initial Settings. Press Menu/OK. Navigate to Ringer Settings and press OK. Press OK again to enter the Ringer Volume sub-menu. Use the Up/Down arrows to set the ringer volume and press OK to save. Press Off to exit the menu system.
The other possibility is that the handset is not registered to the base. Note: only 6 handsets can be registered to the base. If you previously registered 6 handsets, you need to deregister some of them.
To register the handset, hold the handset near the base since you will need to press buttons on both. Press Menu on the handset and navigate to and enter Initial Settings. Navigate to Registration and press OK. Navigate to HS Registration and press OK. On the base, press and hold the Locator button for 5 seconds and the registration tone sounds. Press OK on the handset you are trying to register. If all the registered handsets start ringing, you triggered the Locate handset function. Press the Locator button again. Then do the press and hold step again. Only press OK on the handset when you hear the registration tone.
You can find the manual for the KX-TG4011 here: https://shop.panasonic.com/support-only/KX-TG4011N.html . The direct link to the manual is https://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . See page 21 for the directions to set the ringer volume.
I hope this helps.
(You can't register a handset to an incompatible base. The communication protocols don't work.)
Turn ring on
Do you mean the Panasonic KX-TGA470 handset? The KX-TGA470 handset is the included handset for several models of Panasonic cordless phone systems, including the KX-TG7732. When the ringer is off, the handset should show a bell with a line through it. To adjust the ring volume, press Menu on that handset when the phone is in standby. (The base and handsets are not in use.) After pressing the Menu button, type # 1 6 0. (Alternatively, use the arrow keys to navigate to Initial Settings and press the soft key for Select. Navigate to Ringer Settings and press Select again. Go to Ringer Volume Handset and press Select once more.) Use the arrow keys to select a value between 0 and 7. 0 will keep the ringer disabled. Press the soft key for Save. Press Off to exit the menu.
You can also adjust the ringer volume on that handset by pressing the Volume Up key while the phone is ringing at the base and other handsets. You can adjust the base ringer volume by pressing the + or - keys when the phone is ringing. Alternatively, press Menu # * 1 6 0 from any handset. Note: this phone system also has a silent mode. Press Menu # 2 3 8 to enable or disable the feature. When this is enabled, the handset will show an icon with several Z's.
You can find the manual on the phone system page: https://shop.panasonic.com/support-only/KX-TG7732S.html . The current link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg7731_mul_om.pdf . See pages 23 and 35 for the ringer volume adjustment. See pages 35 and 40 for information on the silent mode.
I hope this helps.
Can't turn ringer on cordless panasonic KX-TGA402C phone.How do i turn it on?
KX-TGA402C is the included handset for a Panasonic cordless phone system like the KX-TG4011C. You should be able to adjust the ringer volume from the Initial Settings menu. With the phone system in standby, press Menu on one handset. Use the Up/Down arrows to locate the Initial Settings. Press OK. Then select Ringer settings and press OK. Select Ringer Volume and press OK. Use the Up/Down arrows to set the desired Ringer volume and press OK to save. Press Exit to leave the menu system. Alternatively, you can adjust the ringer volume by pressing the Volume Up/Down buttons while the phone is ringing.
The manual for the KX-TG4011 is available from Panasonic here: ftp://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . If the above steps aren't working, check that your handset and phone base are properly paired (registered handset). Also check that the base has power and connected to a working phone line. Also make sure that the handset is fully charged.
I hope this helps.
Turn ringer back on Panasonic cordless kxtg101s
The KX-TG101s isn't a model that I recognize. Do you mean the KX-TGA101 handset? If so, that handset goes with the KX-TG1031 base.
If this is the right handset, make sure that the entire phone system is in standby. Press Menu/OK and navigate to Handset Settings with the Up/Down arrows. Press Menu again and navigate to Ringer settings. Press Menu and navigate to Ringer Volume. Press OK and use the up/down keys to set the desired volume. Press OK and then Off to exit the menu system. You may also want to check the Ringer tone in the same Ringer setting menu. The tone may not be set to one that you hear.
See page 24 of the manual, which is currently available from ftp://ftp.panasonic.com/telephone/om/kx-tg1031_en_om.pdf .
I hope this helps. If you still don't hear the phone ring, you may need to check your phone wiring and the base. I often check phone wiring with an old-fashioned wired phone.
How to Turn ringer button on and off for a Panasonic KXT7433
Most of the phones have a switch on the side or end that is labeled ringer. You just move it to the desired position.
4helpful
How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
Top Panasonic Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
