you can also try to check the conenction settings of your PS3 to your router. Do it manuallyyou can also try to check the conenction settings of your PS3 to your router. Do it manually
You can't post conmments that contain an email address.
80130182 means it can't connect to the internetBasically. Here is what you do:
Unplug everything from your router. Unplug everything from your modem, even the cable. Remember where everything goes. Plug it all back in. Switch on again
Turn your router/modem & PS3 off unplug all cables plug them back in & turn both router/modem & ps3 on see if this helps.You may get DNS error code (80710102)... If so try going to the link i have provided and see if that information helps...
PS3 ERROR CODE 8013013E
This error is by an issue with the WEP key.
To solve this error:
Change WEP key to numbers only.
If all else fails, disable security.
that error code is a generic "cant connect to the internet" code. try reseting your router and you should be fine. if not try opening your NAT connection on your routers settings.
You Need to go to internet on your pc and type ps3 network and download the new version and save it in your comuter ...then blug the usb in and copy and pase to your usb and then plug it in your ps3 and then go to via storage media and there you are work nice and fine as normal
