You will need the following items:
1. External USB DvD Drive; Can be purchased from local retailer
2. Your Asus Eee PC Restore Disk; This should have come with your netbook. You can order an additional disk by calling Asus, 888- 678-3688.
3. Once you have the above items be sure all your photos, music, documents, data etc. are backed up to a flash drive or dvd. A factory restore of an Asus netbook will ERASE all personal data on the hard drive. You must back up the data on another device in order to preserve it!
4. Connect the external DvD drive to your netbook and insert the Asus Eee PC Restore Disk.
5. Restart the netbook and boot from CD (usually the default key to boot from CD is F12).
6. Follow the onscreen instructions that are on the restore disk.
7. After installation of all software, update windows and reinstall all your necessary software.
8. Enjoy!
SOURCE: ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
Instructions from Acer
The
other way before Vista starts up is to tap ALT + F10 (at the same time
repeatedly) when the computer is first switched on.. The window of
opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then
it indicates that you have tapped the ALT + F10 correctly, and all you
now need to do is press “Enter” and the Recovery program should load on
your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
SOURCE: i need to reset my acer aspire netbook to back to
reinstall using the backup disc that came with the laptop
SOURCE: i need to reset my acer netbook AOD250 back to
you are going to have get hold of the restore discs or do a fresh operating system installation which will require the partitioning and format of your boot drive pls do proper back up of your data dont bother with your software you might just backup problems
SOURCE: I need to restart my netbook back to factory
Try this....
Get into BIOS (hold down F2 during start)
Find and disable 'boot booster'
Save and exit
Hold down F9 during start
Wait 10 minutes
Resume XP setup
or if you're feeling brave;
http://forum.eeeuser.com/viewtopic.php?id=56930
regards
Zahc
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
hope this helps
hope this helps
