When Labtec sends an update for my WC PRO it downloads OK. When I try to install I get "Internal Error 2378" which prevents installation. Happens every time. I'm running Vista Home Premium on a Dell Dimension E521 that seems to be OK. All checks fail to find the cause of this error. Thanks.
[email protected]
SOURCE: Labtec Webcam Plus installed but keeps telling me it is unplugged.
This is very strange. It sounds like a driver problem, but you said you got the latest drivers from Labtec. I would go to Labtec's support area and copy what you posted her and show it to them to see if they know of any similar issues.
SOURCE: lost installation cd for my labtec webcam,any free download sites
Here is the download page for your camera's drivers. A rule of thumb for me is to NEVER use included software/install disks when I buy hardware, you can find them on the manufacturer's website and when downloading you can more easily find different builds (for example, my printer only came with the disks to install the suite of applications, whereas the basic operational drivers were available online).
here is the download site for your webcam brand, just pick out your model, download, and install!
http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
SOURCE: labtec webcam driver problem
if you have he caera picture you are downloading the wrong drivers.
here are the proper drivers--
http://labtec.com/index.cfm/service/listing/APAC/EN,crid=68,crid2=1764
SOURCE: Labtec Webcam (original) won't work with Vista 64
Follow these instructions and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
SOURCE: Trying to install Labtec drivers for my labtec
You can contact Labtech from here
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
You may have to run it in Compatibility mode if Windows 7 webcam software is not available - I'm sure they can advise you
To navigate to CM on my logitech I rightclick the webcam shortcut icon on the desktop and click 'Properties' and then the 'Compatibility' tab.
