Question about Printronix Line Matrix P5005B Printer
I installed a new logic board for a P5210 and the printer is coming up with a table mismatch error The interface is serial
Posted by damedume on
Anonymous
    Problem Solver:
  • 12 Answers
U need to download firmware..
Posted on Feb 04, 2011
After replacing a logic board on tallygenicom,it desplays the error "sucurity violation" how do i resolve that problem
Security lock was installed in the previous logic board remove the security lock and install it in the new logic board.
Feb 28, 2013 | TallyGenicom Office Equipment & Supplies
E07, e08, e02, e15 error in canon mp258, pl. give meaning of error & solution
Canon Pixma Mp258 Error Code and Possible Solution
P02 (Carriage error)
1.Make sure no foreign material stuck to the print head railway.
2.Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.P03 (Line feed error): an error in transmission line entering the line feed (LF) is a signal telling the printer to move to another line or a whole new line that would not otherwise have reached the end of the line.
1.Check wire print head position (timing **** disk film) on the side of the machine.
2.Check PCB logic board.
P05 (ASF sensor error) sensor for paper feed error.
1.Try to replace the following:
•ASF / PE sensor unit.
•Drive unit.
•PCB logic board.
P06 (Internal temperature error): caused by abnormal heat inside the printer.
P07 (Ink absorber full): the Ink Wastepad (sponge) inside the printer is full
1.Replace the wastepad inside the printer or install waste ink bin outside the printer
2.then Reset counter protection.
P08 (Print head temperature rise error): caused by thermal print head temperature exceeds a threshold.
1.Replace the new cartridge print head and / or change a new logic board.
P09 (EEPROM error): caused by corrupted or defective EEPROM chips of the printer.
1.Replace the logic board.
P15 (USB VBUS over current): caused by too much current, try removing the USB cable and then plugin again, if solve the error, try to replace with a new USB cable. If the error still exist replace the logic board.
P20 (Other hardware error): The failure of other hardware.
1.Try to replace the logic board.
P22 (Scanner error): a scanner malfunction.
1.try to change the scanner unit or change a the logic board.
E13 or E16: Ink has run out
1.Pressing the Stop / Reset button for 5 to 8 seconds until the led screen display number 1.
E04, E05, E14 or E15: Cartridge may not be installed properly
1.Reinstall the ink cartridge.
Jun 15, 2011 | Office Equipment & Supplies
Received message "table mismatch" and priinter
There is nothing to do but try to reflash the printer firmware. If that is not successful then the cmx bd. must be replaced and reflash.
Nov 13, 2010 | Printronix P5000 Printer
Error 950.10 NVRAM mismatch. how do I fix or
The way that I have found to fix this problem is to replace the logic board but when you do that, this is where the NVRAM mismatch comes in. Once you change the logic you also have to change the display op panel. That is what is giving you this error. You must change logic and op panel at same time and it will not give that error.
Apr 08, 2010 | Lexmark E450dn Laser Printer
Nvram mismatch error after replacing the dislay panel on lexmark t644
You have to install a brand new front display, the display board has a backup of the nvram, on boot the system board check the nvram and if it don't match it will return an NVram mismatch error
Mar 30, 2009 | Lexmark T640 Laser Printer
Flash a printer
I can email you the Flash Program.
If a “Table Mismatch” is displayed, recycle power and reflash the printer. Can get “Table Mismatch” after replacing CMX Board.
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: Have Ethernet? You can FTP download.
1. Print a configuration on the printer prior to the download. After the flash is upgraded, the printer will be at Factory settings and you will need this printout to restore any non- default settings.
2. The PTX flash code is on a CD you should have received with printer. Don’t have? I can email you the Flash program.
3. Turn the printer's power off.
4. If there is a cable connected to the printer’s serial port, disconnect it.
5. Connect a cable from the LPT1 port on a PC that has a DOS prompt mode to the printer’s parallel port.
6. While holding down the Online & FF(Paper Advance) keys, power up the printer. The printer will display "Waiting for Program Download".
7. At the PC’s DOS prompt, go to the directory where the file is located C:\Temp and
type "filename.exe -pb<ENTER>" where filename is the name of the file that you downloaded in step 2.
NOTE: there is a space before the -pb
8. The printer's display will keep you informed of the status of the download. When the download is complete, cycle the printer’s power.
Dec 01, 2008 | Printronix Line Matrix P5215 Printer
Printronix5003H+ table mismatch
I'm sure you have fixed your printer by now... but reflash the printer.
Flash memory is contained in SIMMs (single in-line memory modules) located
on the controller board. Printer emulation and operating system software are
loaded into flash memory at the factory, but you will install software in some
situations:
• The customer buys the PGL or VGL graphics, Expansion-CT, or IPDS
option after the printer is installed
• The customer needs to upgrade printer software
• The customer needs different emulation software
• You have replaced the controller board
• You have added or replaced the flash memory SIMM
Emulation and operating system software are stored as a compressed file on
a 3.5 inch floppy diskette. This file is “executable.” You will expand it and copy
it into printer flash memory.
You can load software through the serial, parallel, or Ethernet port of the
printer.
1. If the printer has an Ethernet interface, refer to the PrintNet User’s Manual
for the download instructions. You are finished with this procedure. If you
are going to load memory through the serial or parallel port, continue with
this procedure.
2. Make a printout of all saved configurations. (Refer to the User’s Manual.)
(Installing new software erases all saved configurations. You will use the
printouts to restore printer configuration.)
3. Set the printer power switch to O (off).
4. If the printer is already connected to the serial or parallel port of a
computer capable of running an MS-DOS® based PKZIP® self-extracting
file, go to step 11. If not, go to step 5.
5. Unplug the AC power cord from the printer.
6. Disconnect all data input cables from the printer interfaces.
7. Connect a parallel data cable to the LPT1 port or a serial data cable to the
COM1 port of an IBM-compatible computer that is using the PC-DOS™ or
MS-DOS operating system.
NOTE: You can connect the cable to the LPT2 port if the LPT1 port is alreadyin use. The load commands are different if you use this port, as
described in the note after step 18.
8. Connect the data cable to the appropriate I/O port of the printer.
9. Plug the AC power cord into the printer.
10. Power on the computer.
11. Insert the emulation or upgrade diskette into diskette drive A (or B) of the
computer.
12. Make the diskette drive the active drive by typing the following at the DOS
prompt:
A:<return> (If the diskette is in drive B, type B:<return>)
13. Get the name of the compressed file on the diskette by listing the
contents of the diskette; at the DOS prompt type:
DIR<return>
The compressed file on the diskette takes the form FILENAME.EXE
Now write down the complete name of the file with the .EXE extension.
14. On the printer control panel, press and hold down the ON LINE + PAPER
ADVANCE keys. Without releasing the keys, power the printer on.
Continue holding the ON LINE and PAPER ADVANCE keys down for five
seconds, then release them.
NOTE: The port default is CENTRONICS; this is the standard load through
the parallel port. If you want to use the default, continue at step 18.
15. When you see “WAITING FOR PROGRAM DOWNLOAD” on the LCD,
press the < (NEXT) key. “SELECT DOWNLOAD PORT =
DATAPRODUCT” appears on the LCD.
16. Press < (NEXT) again to cycle through the download ports available in
the printer:
DATAPRODUCT (parallel)
CENTRONICS* (parallel) (default port)
RS232-9600 (RS-232 serial, 9600 baud)
RS232-19.2K (RS-232 serial, 19200 baud)
RS232-38.4K (RS-232 serial, 38400 baud)
RS232-115K (RS-232 serial, 115000 baud)
RS422-9600 (RS-422 serial, 9600 baud)
RS422-19.2 (RS-422 serial, 19200 baud)
RS422-38.4K (RS-422 serial, 38400 baud)
RS422-115K (RS-422 serial, 115000 baud)
17. When the printer download port you want to use is displayed on the LCD,
press ENTER. “WAITING DOWNLOAD / PORT = <your selection>
appears on the display.
18. At the DOS prompt on the computer type:
FILENAME.EXE -pb<return>
where FILENAME.EXE is the compressed file you noted in step 13. This
command decompresses the file on the diskette and copies it as a binary
file into the flash memory on the printer controller board.
NOTE: If you are loading the file using the LPT2 port on the computer, enter
the following DOS command:
FILENAME.EXE -pb 2 <Return>
The 9600 baud rate is the only selection older versions of DOS can
use. The baud rate information entered in the following DOS
commands must match the selection you made in step 16.
the load process and status. (LCD messages are listed in Table 2,
page 37.)
CAUTION Do not interrupt the downloading process once it has started.
Interrupting a download will damage the flash memory on the controller
board and PrintNet card ( if installed).
19. When the new program has successfully loaded into memory and the
printer has reset itself, set the printer power switch to O (off).
20. Unplug the AC power cord from the printer.
21. Remove the diskette from the computer and store it with the printer.
LineMatrix
www.sinca.biz
Toby
Jul 07, 2008 | Printronix Line Matrix P5215 Printer
Table Mismatch Download Again
This is the only Solution to "Table Mismatch"...
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: You have ethernet, you can FTP download.
May 15, 2008 | Printronix Line Matrix P5215 Printer
Table Mismatch Download Again (Printronix P5215)
hi
i have an error " tabel mismatch download again" on my printonix p1000q1
how can i solve it please help me as soon as Possible please help
Sep 14, 2007 | Printronix Line Matrix P5215 Printer
Printronix Line Matrix P5005B Printer Logo
320 people viewed this question
Top Printronix Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Harrie
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
