Question about Skype IM
Fatal error D3DPERF - Skype IM
Posted by rajankhurmi on
Aloke Das
  • 1,833 Answers
This problem comes when you don't have directx installed in your PC. First un-install skype. Then download and install the latest directx. If DirectX11 don't help, then use DirectX9. get it from http://www.microsoft.com/games/en-us/aboutgfw/pages/directx.aspx. Then reinstall the skype. Your problem will go away.
Posted on Jan 24, 2011
J. Van
    President:
  • 1,738 Answers
You will need to install Microsoft Direct X before you install Skype. You can get it from http://www.microsoft.com/downloads/en/details.aspx?displaylang=en&FamilyID=3021d52b-514e-41d3-ad02-438a3ba730ba
And, make sure you have the latest Skype version installed:
http://www.skype.com/intl/en-us/get-skype/on-your-computer/windows/
Thank you for using FixYa.
Brian Sullivan
  • SKYPE Master
  • 27,725 Answers
Many of the d3d9.dll errors occur when you have older version of DirectX on your PC. For instance, you may receive d3d9.dll errors, similar to the ones listed below in case you try to run a game that is specifically written for DirectX 9 on a PC that uses DirectX 8 or some other older version.
also you might
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
hope this helps
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
I wont to use skype but i see fatal error d3dperf
To help you out, I need some more information:
  1. Have you tried uninstalling and reinstalling the skype?
  2. Which operating system are you using?
Feb 13, 2011 | Computers & Internet
Error d3dperf
try using the latest version,download it from here and dont hesitate to ask any questions! thank you for using fixya dont forget to rate or vote me
Jan 16, 2011 | Skype IM
Fatal error d3dperf SetOption(d3d9.dll)
If the ntdll.dll error only displays when you use a specific software program,
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 30, 2010 | Computers & Internet
Failed to get proc adress for D3DPERF Set Options(d3d9.dll)
failed to get proc address for d3dperf set options d3d9.dll while installing skype
Dec 16, 2010 | Computers & Internet
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Skype IM Logo
1,053 people viewed this question
Top SKYPE Computers & Internet Experts
Mike
k24674
Rob Hill
Rob Hill
Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
