Hello there! this is Kimberly Escobar with Dish Network customer support, just ran across your post and wanted to provide you with with information that will be helpful to you. To program your remote to your Vizio T.V you can try using some of the codes we have available that help the remote control functions of your T.V itself. For the Vizio brand one of the codes is 505. what you will need to do is press and hold the clear T.V button located on the upper left hand corner of your remote until all the other top buttons begin to light up, once they light up you let go of clear T.V button and enter the number 505 followed by the pound key (#) as soon as you press pound you will see the clear T.V button flash 3 times. You can can your volume or turning off and on the T.V it should work. For further assistance you should also find this link very helpful http://www.dishnetwork.com/SupportSection/remote-setup as well as contacting us directly. Hope this helps!
We're happy to help you with getting your DISH Network remote addressed to your TV. We're going to start by pressing and holding the TV button on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Vizio TV; here are some of the codes we currently have: 505, 598, 627, 520, and 627. Press the pound (#) button to save the code in your remote. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Vizio TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
