Question about LG Heating & Cooling
My remote has not show any information on the front screen. The batteries are new and the air conditioner works but I can't set temperature because screen is blank. I have a room air conditioner and the owner's manual instructs models: SQ/SR/ST Chassis---inverter models. I need to find out if I can get another remote for this or find another way to be able to use air conditioner.
Posted by janis_murray on
R Subramaniyam Iyer
  • 2,133 Answers
Problem is with Thermostat only. Check for loose contacts. If not, replace thermostat. Helpful?
Posted on Jan 24, 2011
I have an lg inverter air conditioner it look like remote 6711a20128s LG nothing showing on controller screen. I changed battery and all symbols show up only 1s then blank, repeat and same Please help
You have a faulty remote. These are considered consumables by the manufacturer so you'll need to get a new one or universal remote. LG remotes are typically pretty cheap though. You should still be able to turn your air con on by the manual button somewhere on the front panel.
Dec 28, 2015 | LG Heating & Cooling
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
Remote control signals not being received by Samsung air conditioner
Try a new set of batteries in the remote... If that doesnt work, look on the indoor unit , behind the filter screen or on the side for a "manual start or emergency start button or switch" If that works, it may be the remote is faulty. If not the remote, it will be the recveiver board on the indoor unit.
Jul 16, 2011 | Samsung AQ24 Air Conditioner
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as...
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Feb 02, 2011 | LG LSC121PMA Split System Air Conditioner
Ai2hh-2 green flasjing light on unit and remote
The problem of electronic control units in the indoor air conditioner, there are two temperature sensors, sensor pipe evaporator and room temperature sensor. one or both of these sensors is defective, so that electronic controller error and showed signs of a green light flashes and the remote does not work. You must replace both sensors with a new and appropriate size (specification)
Jul 24, 2010 | Heating & Cooling
My 500 protech Ruud thermostat which is new was installed by the dealer powered direct and without batteries. When the electrical power fails the differential and temperature return apparently to a default...
HI; Yes You can pull the cover off(gently) and put in batteries. The installer should have done this for You and should have left You with all the operation manuals. They should also have informed You on how to change the batteries as well...alpharome416
Jan 14, 2010 | Ruud UBHC Air Conditioner
Have an LE room air conditioner, the remote control won't work - new batteries and the manual control on the front panel won't go below 85 for the temperature setting
electronic module of ur ac is not working,try to remoove it carefully (only if u can) and heat all the soldered jointes with a 25 watt soldering iron,by doing so it should work if not then replace the module
Jan 08, 2010 | Fedders Appliance Air Conditioner Wall
For air conditioners is also stay at 64 i dont go up or down whit the remote why
Please elaborate! I'm unsure if your A/C will not change temperature without the remote. Some units have a "lock" which if set, will keep the unit at the same temperature & if it's only not working with your remote, my guess is that your remote is bad or the batteries are dead or placed in it incorrectly (or may have leaked & ruined the remote.)
Jul 02, 2009 | Comfort-Aire HMH12AS-0 Air Conditioner
Heating & Cooling Logo
139 people viewed this question
Top LG Heating & Cooling Experts
Marvin
Marvin
Steve Oakes
Steve Oakes
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
