Question about Acer (91.16848.010) Video Capture
TeHow can I fix my webcam,it say acer video capture device been detected.
Posted by temilee84 on
1 Related Answer
SOURCE: No Acer video capture device was detected on your
you have to use the driver cd which came along with your device and install them and this will install the driver for your capture device and your hardware will be detected.
thanks
Posted on Oct 07, 2010
My acer aspire 5734Z-4360 crystal eye has stopped working. It indicates no Acer video capture device was detected on your system.
Update the webcam driver in your computer. You can get the crystal eye driver from the website of acer. But if you would like to cover all drivers in your computer then you can use RadarSync scan so that you will know which drivers are outdated. Keeping them updated would fix the issues.
David
Jun 07, 2013 | Computers & Internet
Hi, I recently had my acer netbook fixed because my screen had been broken and the ink leaked through the screen. I just got it back and whenever I ry to use my webcam it says 'Error, no video capture...
If the webcam is built into the screen area (I'm guessing it is), then it's likely that it became disconnected while it was being worked on and needs to be reconnected. Take it back to the store and ask a technician to inspect the netbook to make sure that the webcam is connected.
Sep 19, 2011 | Computers & Internet
No Acer video capture device was detected on your system.
thanks
Oct 07, 2010 | Acer (91.16848.010) Video Capture
HOW DO I USE MY WEBCAM ON MY ACER ASPIRE ONE NETBOOK?
Certain models have are shipped with Acer Crystal Eye Webcam software which enables webcam at boot. I do nto know if it is installed in your netbook.
To test the webcam running Windows XP, follow the steps below:
  1. Go to Start, All Programs, then Windows Movie Maker.
  2. On the left side, click the link for Capture from video device.
  3. Select Next throughout the set up, making any file name changes or setting changes if desired.
  4. On the Capture Video screen, click on the Start Capture button
  5. You will see the video on the right with a time count up
  6. When you are done click the Finish button
  7. Click the play button on the video clip, or drag the clip to the Storyboard below.
If your webcam is not detected or if you are running Windows Vista click the link below.
The wesite has live chat support in case you get stuck
http://netbooks-us.custhelp.com/app/answers/detail/a_id/86/related/1/kw/webcam/r_id/166
Jan 13, 2010 | Acer Aspire One AOD150-1920 Netbook
Acer crystal eye webcam
How to Record Webcam Video with Earlier Versions of Windows Movie Maker If you're still using Windows XP, your Windows Movie Maker version might still support capturing video from a webcam. To do this, go to your WMM Movie Tasks and then select "Capture from Video Device". Select webcam from the list of analog devices. You must also select the video input line you want to use for capturing your webcam video. Then enter a name for your captured video file and the location of the drive where you want to save it. Select your video setting preferences for the video you want to capture. To stop capturing, you can either
choose to stop anywhere during the recording session or indicate a specific time limit before the recording stops.
How to Record Video on Your Webcam with Newer Versions of Windows Movie Maker When we say newer versions, we are referring to Windows Movie Maker version 6 which comes pre-loaded with the Windows Vista system. Since Windows Vista is a pretty advanced OS, we expected the latest version of the WMM to support webcam video capture as well. It's very helpful and economical since it comes packaged with Windows Vista, and you don't have to pay the extra cost just to have that tool.
So, the next question now is, how can you record a webcam video using Windows Movie Maker 6. Actually, like we said - you can't. You won't see the "Start Capture" tool in the File Menu of your latest Windows Movie Maker.
Your best bet is to look for alternative and cheaper software that would help you capture whatever you want to record from your webcam. Or, better yet, use the software that comes with your webcam to capture video and then import it into Windows Movie Maker for editing and enhancements. If your webcam didn't come with video capture software, you're in luck because there are free software appllications available for you to download to do such tasks. You can find a good list of webcam video capturing software from this list:
http://www.sharewareconnection.com/titles/webcam-video.htm
Apr 12, 2009 | Acer Aspire 5315 Notebook
To capture video acer aspire 6920 acer crystal eye webcam builti
you need to download a video capturing device
if your system did not come with one
the built in webcam is exactly that for messaging programs and taking snaps but they can be used for video and this is usually something you need to get on your own
debut is usually a pretty good site
please don't forget to rate me
Feb 07, 2009 | Acer Aspire 6920 Notebook PC
I cant find the webcam icon
Use ACER Arcade application.
From User manual:
"Acer Arcade allows you to capture and record video clips from other external
devices, such as a DVD player or camcorder.
Click Capture Device on the video page and then select the source you are using
for your video input. There is a choice between "S-video" and "Composite."
To capture a video clip, you then need to click the red record button in the
onscreen controls.
The destination folder can be set from the "Settings" menu.
Clicking on Advanced and selecting Settings allows you to set the quality of the
video captured. You can choose from "Good," "Better" or "Best." Selecting a
higher quality results in a larger file when capturing video clips.
Snapshot
Snapshot mode is available in Cinema, Video and TV modes. This function can
be used to capture the onscreen image at any time."
Jan 05, 2009 | Acer Aspire 5610-4648 Notebook
Cant make a video with acer orbicam
u can not record video with ur orbi cam bcoz ur acer software doesnt support it if u want to capture video from ur webcam u can capture it thru other video cap softwares like Ulead dvd movie factory, or nero vision or cyber link power producer u can select ur webcam there in capture device list u can also google for any video cap utility that is free
pls rate me FIXYA if u got what u wanted
Nov 13, 2008 | Acer Aspire 5102WLMi Notebook
The best solution: Buy a good computer with a webcam or a simple webcam. The best thing to do is not to buy the Acer 5315-2326
Aug 13, 2008 | Computers & Internet
Televison & Video Logo
102 people viewed this question
Top Acer Televison & Video Experts
Marvin
Marvin
Paul Bade
Harrie
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
