Fisher and Paykel DEGX1 Electric Dryer Logo
Posted on Jan 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer is making a thumping noise even without the vent being on. The vent pipe is not plugged.
Anonymous
Level 3:
  • Fisher and P... Master 43,501 Answers
  • Posted on Jan 24, 2011
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10835053
Points
101584
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Not drying
Hi. When a dryer takes that long, check the entire length of the vent pipe for a partial clog from lint. Clean out the lint and the dryer should dry in just one cycle. Regarding the thump it most likely is a loose or bad roller. J.
Jul 02, 2010 • Dryers
It is not drying very well even on the very dry setting, why?
This may sound silly, but have you cleaned the dryer vent pipe from the dryer to the outside of your house? If that vent pipe is plugged, or partially plugged, your dryer will not dry properly. When I have had this problem in the past, the first thing I do is take the dryer out of the house and blow it out with a leaf blower. I put the leaf blower nozzle in the vent trap area, pack a towel around the blower nozzle, turn it on high and watch the lint fly. This ensure the dryer is cleaned out of any excess lint. Next, I take my leaf blower into the house, put the nozzle in the vent pipe (packing a towel around it also) and turn it on high and blow all the lint out of vent. I would caution you to check your piping the make sure all the vent pipe sections are secure. (The first time I blew out my vent pipe I had lint all over my basement due to poor connections in the tin piping. I promptly took aluminized duct tape and covered all of the seams.) My dryer always drys so much better after doing this simple procedure.
Makes thumping noise without input from receiver
So no wires plugged into it at all? Sounds like a cold solder joint on a board or a bad connection inside the amplifier.
My Kenmore Elite Dryer makes thumping noises when it is not running.
if it is not running and you hear noises. you may have a critter in the vent,or it may be flow reversal from another fan being used, oran outside door beingopened or shut. karl
Loud noise
OK, not too sure about this, but...about the only thing that will make a dryer make the sound you describe is a diconnected vent pipe or a problem with the vent fan. Check to see if the vent pipe is connected first.
Jun 15, 2009 • Dryers
1helpful
Loud noise in dryer, and no air coming out the vent
Check these things:
Unplug or turn off the power to the dryer and turn off the gas (if equipped)
Pull out and examine the lint screen
Pull the dryer away from the wall (carefully), disconnect the vent pipe (the 4" tube) and look for plugging of the vent line (you said the vent dampers weren't open)
Lastly, it could be the vent blower - this is located inside the dryer annd accessible from the back with the back cover removed. The blower could simply be plugged or it could be defective.
May 07, 2009 • Dryers
Our dryer gets hot how ever it takes forever to dry a load of clothes and it makes a huge thumping noise; what could this possibly be.
the thumping is the drum not moving around right you need to change the felt the vent hose must be tight and stright up and out no slack moister needs to be blown out
Feb 18, 2009 • Dryers
Our Asko dryer (T720) has begun to make a heavy thumping noise, even if empty. (Sounds like a single wet & heavy object is in dryer)
Usually the drum rollers wear on that model making a thumping noise. The asko is a tough machine to work on. You may need a technician to service it.
Aug 01, 2008 • Asko Dryers
1helpful
LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Top Fisher and Paykel Dryers Experts
Bill Eager
Virgil Watts
john h
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
