Cars & Trucks Logo
Posted on Jan 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i remove the factory radio on my 1983 cadillac fleetwood
Anonymous
Level 2:
Sergeant:
  • Expert 157 Answers
  • Posted on Jan 23, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
157
Questions
0
Helped
107094
Points
532
Locate and remove two (2) phillips screws that secure the top of the plastic panel that surrounds the radio. The plastic dash panel will pull off once the screws are removed as shown in the photo above.
The front of the radio is held in with two (2) 7mm bolt screws at the top of the radio. Remove the 2 bolt screws.
There is a hidden radio that secures the rear of the radio and is located under the radio. Pull the ashtray to its extended position. You will need to lay on your back or side and look behind the ashtray, up to the bottom of the radio.
Once the ashtray has been pull to its extended position, you should be able to locate and remove one (1) 7mm bolt screw as seen in the photo above.
Once all screws have been removed, the radio can then be removed. Pull firmly on the radio to remove it from the dash. The radio will most likely resist pulling from the dash. The antenna cable which plugs into the rear of the radio is very short and gives the radio resistance when trying to pull the radio out of the dash. Continue to pull firmly and the antenna cable will unplug itself as the radio is pulled from the dash.
Unplug (1) blue, (1) white, and (1) black wire harness connector(s) from the rear of the radio. There will also be wires extending from the rear of the radio with a plastic connector attached to the wires about 4 inches from the rear of the radio. Unplug this small connector. The radio can now be completely removed from the dash. Set it aside. You will need to remove the plastic brackets attached to the top and bottom of the GM radio. This will be shown in detail in the "Mount New Radio" section.
Hope these helps....
Norman Worley
Level 3:
Genius:
  • Master 1,273 Answers
Norman Worley
Master
Level 3:
Genius:
Answers
1273
Questions
0
Helped
324931
Points
3473
Pull the knobs off and look behind the knobs, there are spanner nuts holding the radio by its tuning shaft. Under the dash there is a metal strap holding the back of the radios weight, remove the bolt, and while you are under there, disconnect the antenna feed by pulling out on the cable. The radio can then be removed by pulling it out backwards of the dash.
Belt diagram 1983 cadillac 4.1
"I need all the BELT diagrams for my 1983 Cadillac fleetwood brougham. There are 4 different belts. And the car has been sitting for 3 years. So I wanna replace the belts." ****** yall must cant read? ****
How big is an engine in an 83 cadillac fleetwood
Depends on the 8th digit of your VIN code = engine size.
VIN "6" - 8cyl. 6.0L 4BL (4 barrel carbureted)
VIN "8" - 8cyl. 4.1L TBI (Throttle Body fuel Injected) (95 % of 83 Cadillac Fleetwoods)
VIN "9" - 8cyl. 6.0L TBI (2% of 83 Cadillac Fleetwoods)
VIN "N" - 8cyl. 5.7L MFI (Multi-port Fuel Injected) Diesel OHV (Overhead Valve)
(3% of 83 Cadillac Fleetwoods)
5helpful
1983 cadilla fleetwood fuse box diagram
Here is a fuse panel diagram for that vehicle.
1helpful
I have a 1983 Cadillac Fleetwood, 4.1 litre. Where is the fuel f
if it does not go directly to the carburetor itself it should be just under the drivers seat the one at the carburetor would look small an round and the other under the driver side a round canister fairly the size of a pop-can ...as well you may even trace the fuel lines from the tank up until you locate it
1helpful
1983 cadillac fleetwood brougham 4.1 liter battery not charging
check the alternator fuse that can be a fuse link by the battery pole,check alternator voltage on the alternator red wire or connector,it should the same as on the battery ,check ground wires for loose intermitent contact
3helpful
Finding fuse box on 1983 fleetwood classic & gap needed in plug w
There are 3 or 4, 7mm screws holding a black plastic panel under the dash. you have to reove those to get to the fuse box which is right next to the parking brake. There are two fuse boxes. A main box and a relay box which has a fuel pump fuse and injector fuses. Most spark plugs come pre-gapped to factory specs Gap 0.06
Top Cadillac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Cadillac Expert? Answer questions, earn points and help others
