Even though I'm only trying to burn approximately 1 hour of footage onto a DVD, it is still saying I need 2 discs. Is there a setting I can change to get it to fit on one like it will if I burn it in real time?
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
You can convert mini disc ( 8 cm diameter ) to a standard DVD disc via your PC.
Please follow this steps :
1. Install your canon software/driver in PC
2. Install DVD creator in PC ( common software is use Nero scout)
3. Download your mini disc data to PC
4. Enhanced your data with Nero
5. Burn your data to standard DVD
Make sure you have DVD RW hardware in your PC.
try sothink dvd moviemaker software or dvdvideosoft software from www.cnet.com/download.....most dvd recorders will burn (check your manual for the correct type (+ / -) and brand that works best)...but wont let you play on other machines unless you format and the other machine is just as new as the recorder...(our older dvd players will not play these new dvd)
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
First you need a player that plays divx if it does then try downloading the movie onto a different disc the dvd-r have never worked on my player even though it says they will the dvd+r sometimes works its a crap shoot.
When you recorded your "footage" was the dvd recorder set to 2hr (sp), 2.5hr (spp), or 3hr (LP), etc.?Because for example, you downloaded (recorded to your hdd)your "footage" that is say 3hrs long, and your recorder is set to record at 2hrs mode(sp), then when you put a blank dvd in recorder to transfer from hdd to blank dvd, the 3hrs of your "footage" has been recorded in 2hr mode on your hdd, and will only record in 2hr mode onto your blank dvd. Solution is to set your recorder to the record mode in which your "footage" length is. For example, if your "footage" length is 3hrs, set your recorder mode to LP then when you insert your blank dvd should be okay. Or, set your recorder mode to 2hr (sp) and make two recordings of your "footage" onto hdd, splitting them up: 2hr on one, and 1hr on the other.When you burn to blank dvd you will have to have 2 blank dvds, one for 2hrs, the other for 1hr. I had to same thing happen to me. I hope this works for ya.
mini DVs sometimes can't be access using usb interface, try to look if u have a firewire interface, be sure your laptop supports IEEE1394. power dvd is the best player for dvd files. -r means recordable, not rewritable (rw). if ur not familiar with video editing, you may not be able to burn it to disc, but you can play and watch everytime.
