SOURCE: How to port forward th 2 wire router from web port 80 and tcp/ip port 6100..?
Hi, Here is a manual explaining how to do it... lorexstore.lorextechnology.com/ pdfs/SG19LD804-161_CLIENT_MANUAL_EN_R2.pdf -
SOURCE: trying to use port forwarding
hi!
i tried to remote access your modem using the serial nos. but it didn't give me anything, pls try to run system setup wizard from your computer by accessing gateway.2wire.net or homeportal/setup, once you have configured the modem with your own settings, please let me know and i'll try to open some ports for you
SOURCE: Hello I have a D-Link
there might be a reset switch on the back of the router sometimes near the power supply port if so then press that and the user name and password will be reset to default and the default settings should be either in the manual or on the bottom of you router
SOURCE: am using wireless router of
click on this link select router then the service to forward
http://portforward.com/english/routers/port_forwarding/routerindex.htm
SOURCE: how do i open my ports?
Login to the routers web interface, go to the port forwarding page and insert the information required
