Question about Poulan Pro 22" Self Propelled High Wheel Mower
Does my lawn mower poulan pro model#PR625Y22RKP have a air filter? where is it?
Roy Cagle
    President:
  • Poulan Master
  • 1,545 Answers
Just about all internal combustion engines have some type of air filter. Clean air to any engine is extremely important. Most engines always have the air filter located ahead of the carburetor or the fuel injection system. Yours is probably located on the side of the engine under a cover with a screw in it. The cover may look like part of the main engine cover, but it will be smaller. Check on both sides of your machine, just behind the front of the engine.
Posted on Jan 23, 2011
  • Roy Cagle
    Roy Cagle Jan 23, 2011
    In this picture of your mower (at the front of it) , just on the left side directly behind the front of the engine is the air filter cover. http://homegarden.beanworthy.com/Poulan-...
  • Anonymous Jan 23, 2011
    Got it!!! Thanks
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
Poulan pro 625 lawn mower idles slow and rough
Try changing your plug and check gap and put in some fresh fuel. Empty out the old stuff especially if it has been there a while. Also check your low idle setting on the carb open it up a half turn for starters. Good Luck...
Aug 27, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Where is the oil plug on a Poulan Pro 625?
Hi ca rishell
The oil drain plug is under the mower, look for the pipe plug in the engine housing, be sure to remove the spark plug wire before working near the blades as a safety item...
Free Answer, Please rate me
Apr 16, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Why is there no manual for Poulan Pro lawn Mower PR625Y22RKP? If one came with mine, I have misplaced it.
This site has a lot of manuals submitted by users:
http://www.manualsonline.com/
Maybe you have/haven't checked this site. Maybe a user has NOT submitted any manual for your exact model on the sites you have chosen. Please repost stating what REPAIR help you need and hopefully someone on here will respond.
Aug 29, 2010 | Poulan Pro 22" Self Propelled High Wheel...
I evidently put too much oil in the Proulan Pro Lawn Mower. Now I cannot get it started. It sputters at first but will not start. I have cleaned off the spark plug with a paper towel and sand papered the...
First thing is to remove the excess oil. Take out as much as you need to to get to the line on the dipstick. Next, you may want to use a little WD-40 or similar cleaner to spray into the spark plug hole to thin the oil in there. Replace the spark plug and start the machine a number of times until it runs correctly. Using WD-40, remember the term "little". Good luck...Lee
Jul 22, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
621 people viewed this question
Top Poulan Garden Experts
dannydoesita
Marvin
Marvin
bryan st
Are you a Poulan Garden Expert? Answer questions, earn points and help others
