This sounds ilke its in a delicate cycle or fabric care cycle...did you try putting this in normal or regular wash are the speed selectors set to fast/fast...let me know if this does not help...
it is on fast/fast...perm press cycle...took 4 hours to do a load on perm press.currently on normal was cycle. still starting and stopping. any other ideas? thanks much
yes, check for wiring issues at the terminal block of the motor..also, if you have not tried another cycle..give that a try and change your the setting on speed selector switch to a lower speed..i have seen these go bad causing the motor get two speeds at once..this causes it to short cycle like yours sounds...get back to me with model number it will begin with 110.
