Cars & Trucks Logo
Posted on Jul 17, 2008
Fuse box where is the emergency flasher relay fuse go on a 87 jetta ?
A
Anonymous
Sent e-mail to [email protected] and i gone gived to you one usefull pdf.
A
Anonymous
Wiring relays and connections – all modelsRelays (typical)
1 Vacant
2 Intake manifold preheating relay (carburettor models) or fuel
pump relay (injection models)
3 Seat belt warning system relay
4 Gearshift indicator control unit
5 Air conditioner relay
6 Dual tone horn relay
7 Relay for foglights and rear foglight
8 Relief relay for X contact
10 Intermittent wash/wipe relay
11 Rear window wiper relay
12 Turn signal flasher or trailer towing warning relay
13 Seat belt warning system (interlock) or rear window, driving
lights and oil pressure warning relay
14 Window lift or seat belt warning system relay
15 Headlight washer relay
16 Control unit for idling speed increase
17 Fuse for rear foglight
18 Control unit for coolant shortage indicator
19 Thermo fuse for window lifters
20 Switch unit for heated driver’s seat
21 Switch unit for heated passenger’s seat
22 Switch unit for overrun cut-off
23 Vacant
24 Vacant
Relays are symbolised as a number in a black box
Not all relays are fitted to all models
Connections
A Multi-pin connector (blue) for dash panel loom
B Multi-pin connector (red) for dash panel loom
C Multi-pin connector (yellow) for engine compartment loom left
D Multi-pin connector (white) for engine compartment loom right
E Multi-pin connector (black) for rear wiring loom
G Single connector
H Multi-pin connector (brown) for air conditioner or wiring loom
K Multi-pin connector (transparent) for seat belt warning system
loom
L Multi-pin connector (black) for lighting switch terminal 56 and
dip and flasher switch terminal 56b (carburettor models) or
multi-pin connector (grey) for dual tone horn (injection models)
M Multi-pin connector (black) for lighting switch terminal 56 and
dip and flasher switch terminal 56b (injection models)
N Single connector for separate fuse (manifold heater element)
P Single connector (terminal 30)
R Not in use
Fuse colours
Blue 5A
Green 30A
Red 10A
Yellow 20A
2answers
Have a 1999 k1500 Chevy have no turn signal but do have flashers. This early 99 model left over 98 lol have replaced flasher and directional switch all fuses test good can find turn relay under dash only...
If I am not mistaken, these have 2 separate flashers. One for the turn signals and one for the hazards. If memory serves correctly, the turn signal flasher is square and the emergency flasher is round.
Flasher relay location on 2003 ford explorer
Go to Ford owners manual.com and download the owners manual for free then go to roadside emergencies and your fuse box and power distribution box diagrams are there with the fuse and relays and there values keep it on your phone or computer and print it out when you need it
Where is the turn signal flasher located ?
Hi, first of all locate the fuse box under the dash on the driver's side of the Caravan. Look near the emergency brake. The fuse box cover has two finger screws that you should loosen to remove the cover. Inside you will see a collection of fuses and in the upper right corner a few relays.
Find the turn signal hazard flasher relay in the upper right corner of the fuse box. It should be easy to spot as it is the biggest of the relays in the box.
2answers
My turn signals do not work in my 96 Jetta but the emergency flasher do..so not the flasher or bulbs???
You are right it aint bulb or flasher. Have you checked the turn signal fuse yet?
2002 Jetta TDI, turn signals have stopped working, Where is the flasher and can it be changed?
look in the fuse box the relay is in there it will be coded with the cars fuse box cover and yes it can be changed
1helpful
No signal (turn) do have 4ways fuses seem okay where is the relays?
Sounds like flasher relay. Most cars have located under dash so the sound is audible. Check under dash fuse box. Turn on emergency flashers and listen for sound. Sometimes emergency and turn relays are located together.
Fuse location for directional and emergency signal
The TS flasher and 4 way flasher use different fuses. I'd test the flasher assembly located near the fuse box under the dash. One blown fuse won't disable both but a bad flasher module could,
8helpful
3answers
1999 Jetta fuse box
The fuse box in located on the left side of the dash, between the door and the dash.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
