SOURCE: Can ''Age of Empires'' run on a netbook via SD card?
you can if ur advent is running a windows format, if it is a linux based, you will need a linux copy, but yes you can! you have to install the game to the sd card, just like you would to a regular hdd. I have the original warcraft and warcraft 2 on an sd card, that i use with my ASUS mini....www.computereworld.com
SOURCE: windows boot manager file: /boot/bcd status:
Try check your hard disk with the other machine. Try running hard disk diagnostic test. If there's a problem with diagnostic test i suspect your hard disk is faulty. If you tried connecting with other machine then same problem, suspected also hard disk faulty. You might need to change it.
SOURCE: advent 4211 netbook touchpad not working
Go to the device manager and remove the device. let windows reinstall it for best results
SOURCE: hi i have an advent 4211-b netbook. the keyboard
use virtual key board for fn key do google for it.
