Canon E18 error happens with lens issues. Usually happens when lens gets jammed
or dirt or sand finds its way into the lens. Sometimes it happens for no reason.
You can try to gently tap your camera on the side and see if that helps, but if it does
it will probably reoccur again at some point. Most likely you will need a lens replacement.
Click on "Change your Windows Password" under "User Accounts."
Click "Remove your password."
Type your current password in the field and click the "Remove Password" button.
Click the "Start" button located in the lower-left corner of your screen.
Click "Control Panel" and switch to the "Category" view on the left panel.
Click on "User Accounts" and then "Remove my password."
In Windows XP
hope this helps
