Zebra LP 2844-Z Thermal Label Printer Logo
Posted on Jan 23, 2011
We need the password Is there a default password out of the box?
1helpful
Yes i have a swann srdvr-44350h that im needing a master reset pen for. how do i go about obtaining one for this make and model]
As with all devices of this type it is important to set or change the default password in order to stop anyone accessing your device or changing settings.
The default password Swann DVR password is "12345".
However out of the box the password isn't enabled so you can try leaving the field blank if the default password fails.
To ensure you ongoing privacy Swann strongly recommend that this default password is changed as soon as possible. Remember when choosing a new password make sure its something that others will not be able guess. Password format on the Swann systems is simply numbers.
If you do manage to lock yourself out of the system or have inherited a machine you may need to contact the Swann technical support team.
How do I reset DGTEC settop box parent lock
Try the default password of 000000. Otehrwise you need to do a system restore to factory defaults (also password 000000 by default)
Lost password how can I reset my box
You need to perform a factory reset. the reset button is on the back next the the antenna. press and hold for 10 seconds - the router will then restart. This will reset the password to the default.
the default password is password.
Do not know know password for wireless internet
Hi
Go here and download the manual http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
You will need to reset the router or change the password in the router 1. To change the password, goto Internet Explorer 2. In the address bar type 192.168.1.1 3. Press enter key 4. YOu should see a box with username and password fields. 5. username is admin 6.password is password 7. These are not the wireless passwords but the access password to get in the router. 8. Once in the router interface on Internet Explorer; goto the wireless sections and change the password there.
To reset the router WARNING: This will reset all the settings to what it was like when it came fresh out of the box. You may need to know some other settings. Restoring the Default Password and Configuration Settings You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 5). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Failing this, please refer to the manual, page 29 onwards
All the best now
Phil
How do i create a password for my linksys
you have to access the router configuration page by typing the default ip address of the router http://192.168.1.1 in your browser when you hit enter it should pop up a login window asking for Username and password. by default from the factory Username should be left blank and the default password is admin
this will get you in the configuration screen click on the administration tab and there you will find the password boxes. make sure you type the same password on both window boxes then click save settings on the bottom
PS. don't forget your password otherwise you will need to reset the router by pressing the reset button on the back of the router and you'll have to repeat the whole process
good luck
5helpful
Samsun corby plus default password
The default password should be all zeroes. Just push 0 as many times as you can to get to the end of the password box. Usually it is eight 0's. Hope this helps!
I need to change network key in my wireless router...how?
Hi Friend,
In order to change the network key kindly follow the steps:
Please connect the router to the computer first.
1.Start> Run.type cmd and hit enter.
2.In the black box type ipconfig/all and hit enter.
3.Kindly note down the default gateway.
4.Now open internet explorer and in the address bar
type the default gateway number and hit enter.
5.If you have not changed the default password of the router then kindly do not type anything in the username box and in the password box type admin and hit enter.
6.In the setup page click Wireless.
7.Under wireless tab click wireless security.
8.Select the security mode or if it is already selected then you can change the password.
Kindly set the password something that you can always remember.
Enjoy
Regards
Chiranjeet
1helpful
2answers
Typing in the ip#, getting to the d-link page, admin not working in password box
If it is the default login you should type admin for the user name and leave the password blank.
If you need to reset to factory defaults do this:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
I had my Laptop worked and it was reset back to out of box
You need to RESET your wireless router. Her is how: Press and hold the Default Reset button until the test light blinks on (about 10 seconds). Release the Default Reset button and wait for the router to reboot. The default administrator's password is password The default IP is 192.168.1.1 Hope this helps
2answers
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
