You may try these steps. If you are facing a 90/180 degrees rotation issue with your displayed screen, this can be either due to a problem with your graphic card or a wrong manipulation of the hot keys of your keyboard. This problem can be easily fixed if you follow the steps below:
Solution 1
Solution 2
Solution 3
You can also make use of the hotkeys to change the rotation of your screen
Press CTRL+ALT Gr+Up/Down/Left/Right arrows
Solution 4
If none of the above solutions has solved your problem, this might be due to a bad configuration of your graphic card. I will strongly suggest you to contact a computer technician to fix this issue.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
