GE PDW8200NWW / PDW8200NBB Dishwasher Logo
Posted on Jan 23, 2011
I have a ge profile pdw8200 dishwasher. it goes thru a patial cycle then shuts off. now i have no power to the control panel. could it be a problem with the control panel. if so are they expensive and difficult to replace?
1 Related Answer
Anonymous
  • 1543 Answers
  • Posted on Jan 23, 2011
SOURCE: i have a ge profile pdw8200 dishwasher. it go thru
Check the electrical connections where the power enters the dishwasher. (behind the lower kickplate, on the right side of the machine) Open the metal cover, hold on one of the twist on wire connectors, and firmly tug each wire to make sure none are loose. Check all the wires. There is a good chance one of the wires will come right out of the twist on wire connector when given a tug. Correct the poor connection, and you should be good to go.
1helpful
I have a ge profile pdw8200 dishwasher. it go thru a patial cycle then shuts off.
5helpful
2answers
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Dishes and glasses on the top rack aren't getting clean. Soap left in dispenser cup after cycle GE PDW8200
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
i
GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
2answers
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
1helpful
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Start button on the HMI won't work
There is a ribbon cable that connects to the control panel. Mine was operating the same as yours. I opened up the front and reinserted the cable and its been fine ever since. you need to take all the screws out from the door panel inside the washer to geet to it.
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
