Question about Ovens
I have a GE spectra eterna series gas range. The range top is working fine but the oven does not heat up. We did replace the gas gage/valve a couple of years ago, and I don't think that's it, because the range top is still working. I do remember that the last time the oven worked I turned off the oven before I turned off the beeper. I have unplugged the oven to see if that would reset it, but that didn't work either. Do you have any suggestions? Thanks!
Posted by carladillman on
Carl Schulzetenberg
  • 1,543 Answers
Most likely you need to replace the oven's glow bar igniter.
Posted on Jan 23, 2011
We have a GE Spectra Profile 10 years old ( gas) and it will not heat up all you can do is broil
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 15, 2011 | GE 30 In Freestanding Gas Range ...
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
heatman101
Apr 17, 2011 | Ovens
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | GE Ovens
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
Mar 02, 2008 | Ovens
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Pilot heats up but gas will not come into bar with little holes in oven
Check the voltage at the oven gas valve, if you are getting 120v, then you have a bad gas valve.
Aug 08, 2007 | GE JGRP20 Gas Single Oven
Ovens Logo
308 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
