Question about Kenwood DVF-3080 DVD Player
I tried putting a new DVD into my player ( Kenwood DVF-3080) It's asking me for Parental Control Limit code. I've never set parental controls due to the fact that I have no children. Other DVD's play just fine, and the new DVD i bought is rated PG. Any help is appreciated. Thanks.
Chris Ramirez
    Scholar:
  • 145 Answers
If all the other DVD s you have work fine it could be misreading the DVD try fully RESETTING the power to the DVD Player by removing the power plug from the Wall, if the problem is still there and all the other DVD s you have work just fine then the problem is with that one DVD you have let me know if you need any more help.
Posted on Jan 23, 2011
  • Anonymous Jan 23, 2011
    Thank you oagog, but that didn't work. I just don't get it.
  • Chris Ramirez Jan 23, 2011
    are you having this problem on ALL DVD s or just that single DVD?
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
Can't figure out my parental settings code bought it from a pawn shop
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
May 06, 2011 | Sony PlayStation 2 (PS2) Console
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
Need to reset code
Found this on another site, from personal experience but its very well written so here you go.
The Playstation 2 is not only a video game system, but also a DVD player as well. In many families, the Playstation 2 serves as the "kids" DVD player, which means that many parents choose to take advantage of the parental lock feature to limit what kinds of movies the Playstation 2 will play back.
There could be instances where you entered in a parental code months ago, and now can't remember it. Or, you may have purchased a used Playstation 2, and you never knew the code to begin with. If you or the prior owner set a parental lock code, the Playstation 2 won't play back many movies without entering the code first. You could try to hunt down the original owners, or start inputting every code possible starting with 0000, but it's easier to reset the password and disable parental lock using a secret code.
Here is the procedure to reset the parental lock code:
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Please rate accordingly
Justin
Jul 28, 2010 | Sony PlayStation 2 (PS2) Console
Need master pass code to a ps2 to play movies
There is no master pass code, but there is a code to reset the parental settings. It's important to note that 7444 is NOT the password. You have to hit SELECT when asked for the password. That is where you enter 7444 to clear the code.
Oct 14, 2009 | Sony PlayStation 2 (PS2) Console
Parental control on disney princess television
the master password is 5963.....after you enter that it will ask you to create a new password.
Mar 28, 2008 | Disney Princess MCP DVD2050P DVD Player
Ps2 dvd player
If you want to code free parental control then here is the solution when you are asked to put the code press select, then insert "7444" and your code will be deleted and you will be asked to put new code so put a new code, if you wanna completely remove the code, so during the film press select and go to setup and then parental control and select to turn off the parental control
Jan 08, 2008 | Sony PlayStation 2 Slimline Console
Ps2 slimline parental control code
try this
  1. Bring up the screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
Dec 22, 2007 | Sony PlayStation 2 Slimline Console
Kenwood DVF-3080 DVD Player Logo
140 people viewed this question
Top Kenwood Televison & Video Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Andrew Taylor
Andrew Taylor
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
