If you have any functionality at all left to your touch screen, try to recalibrate it within the settings menu. Otherwise, remove the battery, wait about 15 seconds, then reinstall.
If that doesn't help, the touch-sensitive surface glass has gone out. Apparently, this component in the first-generation Eternity has chronic failures.
Replacing it is not too much trouble for an experienced cell phone technician. But, it's not for anyone who doesn't like to tinker with small things. Here's a video demonstrating the entire process: http://www.youtube.com/watch?v=QJpHHs9QM5U.
SOURCE: Samsung Eternity A867 Phone freeze.
somebody typed invalid unlock code too many times. Now you need unfreeze code. This code can not be supplied byt AT&T. You need to use usb cable to read unfreeze code. There is no free solution. You must purchase software to make it :(. You can purchase A867 unfreeze code reading software at FastGSM.
SOURCE: pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
SOURCE: how to reset my Samsung Eternity SGH-A867
Master-Reset: all personal data will be deleted *2767*3855#
SOURCE: Samsung A867 eternity unfreeze code.
I got my unlock code to my samsung a867 eternity and when i put it in the phone said that its in phone freeze.. What is this and how can i get it fix
I tried re-flashing the operating system on the phone. But, it did not help. A workaround (discovered by my wife) that seems to work temporarily is to disconnect the battery and leave the phone face-down overnight. This has only gotten the touch screen to work for a few minutes each time. But, if you do not plan to fix the phone, this may at least give you enough time to set the USB mode to "PC Studio". While the phone is set for that mode, you can use Samsung's PC Studio software to offload your contacts and media files. I recommend wiping out all data when you are done, including onboard flash, SIM card flash, and SD card flash.
