Question about RCA L42FHD37 42 in. LCD HDTV
What are the comcast remote codes for Sony HT-SS370 home theater system?
Posted by annamuneton on
Anonymous
    Scholar:
  • 145 Answers
If you have this comcast Universal Remote - Red OK/Select Button here are the codes Sony 11100, 10000, 11317
if this doesn't work use the search mode
Searching For You our Code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TVTV key blinks twice, then release Setup.
3. Enter 9 - 9 - 1. The TV key will blink twice.
4. Press and release the digit 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device
5. Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
6. Press Setup once to lock in the code.The TVTV key will blink twice.
7. To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the device you are searching for.
Checkcking the Codes
If you have set up the remote control using the Searching For Your Code
procedure, you may need to find out which five-digit code is operating your equipment. Perform the following steps after setting up your devices to find out which five-digit code operates your equipment. For example, to find out which code is operating your TV:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
3. Enter 9 - 9 - 0. The TV key will blink twice.
4. To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the TV key blinks (e.g., 3 blinks =3) and write down the number in the left most TV Code box (at end of this section).
NOTE: If a code digit is "0", the selected mode key will not blink.
5. Repeat step 4 four more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the fifth digit. Finish writing down the code in the TV Code boxes (at end of this section).
It can be a pain but once you get it down its a cake walk.
Posted on Jan 23, 2011
kosta_san_fr
    New Friend:
The code for ht-ss370 is 31758 ! To program your Comcast remote :
  1. Turn on the TV or other device that you would like to program.
  2. Press the AUX button on your remote
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the code for your device listed above. If you perform this procedure correctly, the red light will blink twice. NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
    enjoy )
    Constantine
Posted on Feb 09, 2013
  • Sophie Turgeon
    Sophie Turgeon Nov 10, 2013
    None of these above solutions worked for my issue
Hi I am unable to program my COMCAST remote to control my DAV-HDX275. I have tried all codes suggested by comcast in vain. Help please
These directions also work for Sony DAV-IS10
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helpsicon1.png you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changesicon1.png you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Powericon1.png = 32719
Good luck. Let me know if it works.
Aug 14, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
When I turn the Sony HT-SS370 on it flashes Muting On until I turn it off and back on again. Has anyone ever experienced this before?
Have you looked at the manual?
UNmute it with the button to the left of the +/- button on the remote.
Page 9, 11, 12, 13, 67.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-HT-SS370-Home-Theater-Systems-manual/id/23641ci059/t/2/
Apr 23, 2011 | Sony HTSS370 Theater System
I calibrate my surround sony sound sound HT-SS370 but the rear speakers don't have any sound. i do hear the beeping from each speaker during calibration but yet no sound from rear speakers!
its a problem with the volume to the speakers, aslo you will only hear it when is called for, not all the time. Its surround sound, not quadro fonic
Mar 25, 2011 | Sony HTSS370 Theater System
I'm trying to find the code to enter into my Comcast remote to turn on and off my Samsung HT-C6900W BLU-RAY home system. The ones listed in the comcast code sheet do not work.
This is not a solution - just more information. I chatted with each of Samsung, Motorola and Comcast. Each said the determination of the code was someone else's "responsibility". Comcast gave me additional codes - none worked. I tried the "learn" process for the Comcast remote. It got me half way there. It will turn my HT off, but not on - go figure. Unfortunately, I think this is just another example of Samsung building and selling stuff without being sufficiently concerned with how consumers will or can use it. Why can't anyone other than Apple figure out that these are consumer devices first and foremost?
Feb 14, 2011 | Samsung HT-C6900W Theater System
Program a Comcast Custom DVR 3 remote for Samsung HT-X40 system
What is the color of the Select/OK button on your Comcast remote: is it red or grey?
Feb 24, 2009 | Samsung HT-X40 System
Code for Comcast remote for Sony DAVHDX275
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Sep 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Comcast on demand custom dvr 3 device codes for sony dvd-hdx576wf
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Aug 06, 2008 | Audio Players & Recorders
I need device codes for sony DAV HD279w home theater/dvd player controlled by comcast digital cable remote control (none of the codes work in the manual and I tried searching for code and still no luck)...
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Jul 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Comcast remote and need code for a samsung ht-tq85 home theater
http://www.ehow.com/how_2116903_easily-program-comcast-remote-control.html
May 17, 2008 | Televison & Video
RCA L42FHD37 42 in. LCD HDTV Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
