SOURCE: Garmin Nuvi 350 Calibration Issue
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
SOURCE: Cant calibrate my Garmin Nuvi 255 GPS
You have the wrong procedure. Please see this link:
http://www.sharc.net/discus/messages/6/77.html?1236709210
- Jim
SOURCE: The right 1/3rd of my Nuvi 750 is grey, have tried
If 1/3 of the screen is grey, this is an indication that the LCD display is defective and needs to be replaced. This can happen if the unit has been dropped.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
SOURCE: display reads no detailed maps found that support routing.
Try a Master Reset:
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
To perform a Master Reset on the nuvi 2xx series device:
Note: A master reset
will erase all waypoints or favorites and will restore your unit to the default
factory settings. But who cares if you have problems, right?
The device will automatically reset. Follow the on screen prompts then place
your device in an area with a clear view of the sky until it acquires
satellites.
Your touchscreen should now be recalibrated.
If the screen is still not responding, then the unit will need to be replaced with a new unit at this time.
With Best Regards,
Benjamin B
Product Support Specialist
Automotive Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Benjamin B, Associate #6891
Additional solutions may be found at http://www.garmin.com/garmin/cms/site/us/support/searchsupport
