Question about Amana AOGD2750 Gas Double Oven
AMANA ARG7301 BAKE FEATURE NOT WORKING CORRECTLY
Model #ARG7301WW
SERIAL: 9710232146
Hi All,
About 8 months ago the "SELF-CLEAN" Feature stopped working, so I would manually clean the interior with elbow grease or "Easy Off" Oven Cleaner.
This past week the SAME thing happened to me, it would take forever to cook something. The burners work fine, as does the Broil feature.
I am taking on the grueling task of trying to remove the bottom part which goes over the flame.
I can see a flame towards the rear of the oven, but no heat is coming from the front part. I think this may be clogged with something, but am not sure.
I am pretty handy, but have never done work on this particular appliance, I know it shouldnt be that difficult, because the bottom burner works in a similar fashion as a grill burner. What I would like in addition to a solution, is some advice on HOW or WHAT to use to clean the blockage? A wire Brush perhaps?
Thanks in advance!
Callie
3 Related Answers
geemarie
Gayle Ashbach
  • 876 Answers
SOURCE: Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Posted on Aug 21, 2008
Anonymous
SOURCE: I have Amana Insta-Broil self clean oven. The
my amana self cleaning oven was in storage for 2 yrs. Hooked it up and all burners work and broiler but oven won't kick on.
Posted on May 09, 2010
Anonymous
  • 1430 Answers
SOURCE: have an amana self
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Nov 19, 2010
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to [email protected] . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire Model FGF366BCA range Problem: Baking function & oven cleaning function stopped working, (broiler works fine).
I used the self clean feature on mine and found that it got so hot that it burned out the sensor and ended up with the same symptoms you are describing. Had to have the sensor replaced. DO NOT USE THE SELF CLEAN
Mar 11, 2011 | Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. [email protected]
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Amana AOGD2750 Gas Double Oven Logo
154 people viewed this question
Top Amana Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Amana Oven Expert? Answer questions, earn points and help others
