Hi,Sir/ i have lcd monitor Hp-L1502 its on position wen i start lcd without vga cable to frount lokation is red+green+blue colours step by step fliker&i can fix new vga cable.whats sulution?
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor. 2. Connect the monitor into different power outlet. 3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Okay...after a bit of trawling the net I found an almost correct pin out. It was not identical to my broken connector however after a bit of checking, I found that all the screens on the cable were common so I wired the connector as follows and all was well! :-
1 Pink
2 Grey
3 Light Blue
4. Violet
5. Link to 6,7, and 8.
6. as above plus a link to the drainwire next to the foil screen.
7. Link to 8,6 and 5
8. Link to 7 and 6 - just use some solder!
9 Dark Blue
10. Red
11. Black
12. Brown
13. Orange
14.Yellow
15 Green
I used a diecast 9 way backshell and tied the cable braid screen to that so everything properly screened.
Plugged it in and away it went!
Hope this is helpful in the future.
Best regards
Victor.
