Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
SOURCE: How do I record my own message for the answering machine?
1. Press and hold down the announce button.
2. You will hear record announcement after the tone.
3. Once you hear record announcement after the tone continue holding the relase button and record your message.
4. When you are done recording release the release button.
5. To hear your recorded message press and hold the release button and release after you have heard your message.
6. If you are not pleased with your recorded message, repeat the steps obove.
SOURCE: how to set message for answering machine lost directions
I lost the directions for my NW Bell GHZ answering machine. I would like to change greeting and set the time. How do I do this? It is model 36288.
SOURCE: uniden telephone answering machine
Replaced my battery for my Uniden 900MHz phone and lost my instruction book..Need to program it again for memory numbers.
How do I do that?
SOURCE: How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
SOURCE: How do i record a
Record a Personal Greeting
1. Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
2. Press 8 (RecNewGreeting).
3. Wait for the system to say "Record greeting," then begin speaking.
4. When you're finished, press 8 to stop recording. The system plays back your new greeting.
5. To keep this greeting, press End. To re-record it, go back to step 2.
Or you can get the manual on the link below page 17.
Good Luck
