SOURCE: 1996 Buick regal over heating
Check the sensor and wiring from it for a short.
Hope this is an easy fix for you.
SOURCE: heater core replacement
OK, Ifound the problem with mine. Dont unplug your air dryer. I checked the 2 hoses coming out from the heater core and still one was hot and the other not hot. The top one comes from the radiator fill tank and the bottom one comes out of the core and goes around to the front and into the water pump. I disconnected both close to the core and could runwater through both directions so upon further examination, I disconnected the hose at the water pump and no water flow. The hose was plugged up with something. Once I cleared it with a hanger and reconnected it I had water flowing through the core and great heat. Hope this is your problem too as it is aneasy fix
SOURCE: Low Coolant light flashing on 1996 Buick Regal 3.8
The low coolant sensor should be located in the passenger side radiator tank, You need to take it out and clean the sludge off of it for it to work right. Or you can just unplug it and forget about it, the light will go out and it won't cause any problems.
SOURCE: Steering on a 94 Roadmaster wagon jams suddenly
make sure the return hose for the power steering is good and the drive belt is good if the car has over 40,000 Miles on it i would change the belt as well Happy Holidays as always wish you the best of luck Michigan Man.
SOURCE: no heat in my 1994 roadmaster wagon i replaced
If you have the Auto temp control; and you have checked the coolant level then you may need to replace the module that is under the dashboard on the right side footwell,. this is a common problem on these cars. When you remove the plastic under dash panel, look up and there is a module in the duct for the heat that determines the temp so the Climate control works correctly. I pulled mine out of a junkyard car and saved about 80 bucks.
