Black & Decker Firestorm Slide Battery  Logo
Posted on Jan 22, 2011
FS240BX battery how Long should it take to charge.
Chris Kelly
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Jan 22, 2011
Chris Kelly
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
21343
Points
71
Hi .Charge the battery initially for 9 hours.
After the initial charge, under normal usage, your power pack should be fully charged in 3 to 6 hours. If the power pack is run-down completely, it may take up to 6 hours to become fully charged.
The red light is just a power indicator. The light will not go out, change color, or blink when the charging has been completed.
To prolong power pack life, avoid leaving the power pack on charge for extended periods of time (over 30 days without use). Although overcharging is not a safety concern, it can significantly reduce overall power pack life.
The power pack will reach optimum performance after being cycled 5 times during normal usage.
There is no need to run the batteries down completely before recharging. Normal usage is the best method of discharging and recharging the batteries
Hope this was of some help to you.
Why is the green light blinking on the Ryobi charger with the battery in it
My Ryobi 18V One+ charger blinks green while it's charging. When the battery is fully charged, the LED goes to a solid green. However, one battery recently had a faulty cell. After several hours on the charger, the green and red LEDs both were blinking. That indicated that the battery failed late in the charging sequence. It didn't fail the initial testing by the charger. The other battery I charged that day charged fine.
The extended capacity batteries can take 12 hours to charge in my experience. The regular batteries take less time. The charge time will depend on the battery chemistry(The older NiCd batteries take longer to charge then the Lithium batteries.)
I hope this helps. Assuming you aren't dealing with a cold or hot battery or charging environment, if you have any suspicion about a faulty battery, replace it.
(Note: I have a 12V drill as well. Those batteries takes longer to charge for the same relative capacity than the 18V NiCd batteries.)
2answers
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
My battery will not charge in charger
The charge adapter may be faulty.
OR
If therecharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
2answers
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
3helpful
4answers
Phone won't charge
Hi, The Li-ion battery cahrging circuitary is some what complex. For most chargers, the charging procedure is divided into three main phases: ? Pre-charging phase ? Constant-current-charging phase ? Constant-voltage-charging phase In the Pre-charging phase, it utilizes low charging current to protect the battery. However,in most recharging situations, the charged batteries still have some voltage remaining, so the charger does not need to apply this action, and just passes it on to the next charging phase. The constant current and voltage charging phases are the main charging phase for recharging the batteries, where most of the charging energy is transformed into the battery. The maximum charging current for a battery depends on the battery?s rated capacity. For example, one battery rated 700 mAh usually can be charged at 350 mAh to 400mA, for faster charging effort. When the charged battery is Li-Ion, in the last charging procedure, the microcontroller normally maintains regular charging voltage while monitoring charging current to determine when the charging procedure should be completed. When the battery is fully charged, most of the electrical energy is converted to thermal energy, which can result in high battery temperature. In this case, the temperature monitoring function will be added for the solution. But since most Li-Ion batteries on the market also have an over-charging protection function, the temperature detect function is rarely used. So it is better to get your phone charging circuitary checked at a local store rather than to make a charger,coz both may cost you almost same. all the best my friend. regards sreejith
Top Black & Decker Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
