Question about Lanier 1205 Copier
Lanier model 5627,fault code SC542 upon power up
Posted by myticobra on
santosj27
  • 263 Answers
Try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And thats it
Posted on Jan 22, 2011
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
I have 200 problem for code sc542
Fusing temperature warm-up error The fusing temperature does not reach the fusing standby temperature of 45oC (113oF) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50oC the fusing roller does not reach warm-up temperature.
Jan 13, 2014 | Ricoh Aficio Mp5000 Lanier Ld050
Service code SC546 on Model 5627
SC546 is universal in Ricoh, Lanier and Savin. It is indicating that the machine does not see the fuser.
Apr 26, 2011 | Lanier UNKNOWN
How do I reset a Lanier 226CN Printer with an error code: SC542
In order to clear error SC542, you can perform the following:
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arrow to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
Please let us know if this works for you.
Also, check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made. read this TSB on updating the thermistors: TSB_106 SC555_SC545_SC542 Occurs.pdf (need to register to views).
Hope helps.
Apr 04, 2011 | Lanier LP231CN Laser Printer
SC542 error code
Without a model, I can't give you a lot of information, but I am assuming it is a Ricoh machine (Possibly Lanier/Gestetner, same difference), as that's the format of their error codes. An SC542 error code is a Fuser Temperature Error, meaning that the fuser didn't warm up fast enough. It is extremely likely that you will have to replace the fuser unit before the error code will go away. Please give me a model number if you need more information and I will try to be a bit more precise with the information. Thanks.
Feb 28, 2011 | Office Equipment & Supplies
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
Lanier model 5627 with fault code sc542 upon power up.
LOL I think I already gave you a solution try this:
6. Turn ON
And thats it
343 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
