Question about AEG 23 in. 6410KF-N Electric Cooktop
How to un lock - AEG 23 in. 6410KF-N Electric Cooktop
Posted by info79326 on
Anonymous
My hob unlocks with that I turn on the hob and the the L appears, then I hold down the lock button until it disappears then I push the STOP/GO button.
Posted on Mar 25, 2011
How do I unlock Model No 76012086
Hello Anne,
Even with your model number I was unable to get a good description of your control board (or part availability)... or manufacturer (seems to point ti induction cooktops)... Sorry.
Your question peeked my curiosity because I had no idea there was a lock... The instructions say to "hold/press" the button/icon down for 5 seconds and the cooktop/oven should UNLOCK...
We are LOOKING for a symbol of an UN-LOCKED Padlock.
The instructions go on further to say... if this does not unlock
your appliance you need to have a service technician look at your CONTROL BOARD.
Hoping for a reset... READ THE MANUAL (failing that)...
I would recommend FIRST (before total capitulation)... trying to find the associated CIRCUIT BREAKER and shutting off the power... for at least a minute.
If that action does not provoke more cooperative behavior from your cook top INCREASE the time intervals (some better appliances use pretty good capacitors for holding memory settings... while others use terrible caps... (one of the biggest reasons for circuit board failures)).
In ANY CASE... I would try many more things like hunting up parts or online videos before inviting the Samsonite Gorilla to take one of my appliances apart (again).
Hoping the 5 seconds works for you!
Dec 29, 2015 | Cooktops
Hob locked and cannot find manual on how to un lock
press and hold each button for 10 seconds until it unlocks
May 06, 2015 | Cooktops
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
How to un lock my GE Profile Induction cook top?
Try turning off the breaker for at least 10 min and re apply power. If this doesn't work, then there's an internal problem.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
Nov 15, 2010 | GE Profile JP930 Electric Cooktop
How do I remove my electric cooktop...the conduit enter thru an L connector into the cooktop and prevents it from being lifted out...I cannot figure out how to get under the control knobs to access the...
On link below is a install manual It might not be yours but they are all pretty much the same. It will tell you how to install. You just do the reverse to remove.
Also you do not un wire the cooktop from the cooktop but from the junction box in the wall. Please make sure the breaker is turned off before you un-wire it.
http://www.jennair.com/assets/product/JEI0430ADS_Installation%20Instruction_EN.pdf
Apr 17, 2010 | Jenn-Air Cooktops
Our two burners on the right are not igniting, can you tell us why? how do I fix it ? the two on the left are fine.
judging by your post I can only assume that the range is gas. If so then the left and right side are controlled by two separate ig-niter boxes and one of them have failed. In order to repair it you will need to locate the ignition module's. They are usually located under the plate that houses the knob assembly. To determine witch one it is you will need to un plug the range and disconnect only one of the burners. Plug back in the range and try to fire one of the burners that works and see if it is not working now. If it is then you have un plugged the correct one. Again un plug the range and finish the removal. Sense this is Jenn-air then you will need to order the new one from them. Hope this helps. Good luck.
Dec 02, 2009 | Jenn-Air Cooktops
How do I know when my stove is done self cleaning?
to get all the detailed instructions
just click this link directly
http://www.applianceaid.com/selfclean5.html
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
thanks.
Nov 11, 2009 | Kenmore Cooktops
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Water splashed on my siemens glass stove and locked.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 19, 2009 | Siemens 32 in. EH78754EU Electric Cooktop
AEG 23 in. 6410KF-N Electric Cooktop Logo
561 people viewed this question
Top AEG Cooktops Experts
Marvin
Marvin
Paul Carew
Andrew Taylor
Andrew Taylor
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
