Question about Toshiba M675 VHS VCR
SOURCE: Model W528
find your model number here, and the manual in Adobe Acrobat format http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/vcrct.asp
Posted on Jul 23, 2007
SOURCE: toshiba vc-522
www.toshbia.com go web site dl manel shows u codes toward back pages k
Posted on Oct 07, 2008
SOURCE: Toshiba VCR auto clock does not work, not way to set it. Please answer right away
you know it would be easier to help you if we knew what Toshiba vcr it is. it is usually easy to set clocks now. you push menu or setup on the vcr remote and there s usually a option to set the clock. only thing i can tell you right now is look here and type in yoru modle number on the vcr and see if ther eis a oweners manual on the site.
Posted on Mar 04, 2009
SOURCE: I need to find an owbers manual for a Toshiba M675
The M674 should be similar to the M675. Try the manual download at
http://www.retrevo.com/support/Toshiba-M674-VCRs-manual/id/284ci068/t/2/
Let me know if this solves the problem. Thanks.
Posted on May 13, 2011
the VCR should record even without a tv attached. The VCR will display what channel it is on. The TV is only for viewing.
Cable hook up is ..
1. from the wall (or antenna) to the VCR input jack
2. from VCR output jack to TV input jack
Most TVs use channel 3 for VCR viewing. You will need to hit the TV/VCR button on the VCR also.
