Question about Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON AN ANNUAL BASIS FOR THE PHASER 8500 / 8550. (095205219357) PC Notebook
My xerox pro 420 have U9 error? - Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON AN ANNUAL BASIS FOR THE PHASER 8500 / 8550. (095205219357) PC Notebook
Posted by addijaanshai on
specialistel
    Brigadier General:
  • 8,909 Answers
The U-9 code means the main control unit/switch board has a problem, replace the board.
Posted on Jan 22, 2011
E6 error on Xerox WorkCentre 420 PRO
ur side or front covert is properly shut.u can cross check this by cheating the interlock switch with a screw driver.
Jun 06, 2011 | Xerox Office Equipment & Supplies
Message erreure U9
U9 in wc group is problem with HVPS. check charge & trf corotrons for leakage. isolate with removing charge or transfer corona each at a time.... U9 disappears; Reinstall HVT. Clean charge corona sawtooth & grid; tighten the grid on charge corona assembly.
Jan 23, 2011 | Xerox WorkCentre Pro 320/315 XL
What is error U9?
This error has been detected with the power
supply cooling fan. Do the following steps :
Turn off the printer
wait 15 seconds
Then turn on the printer.
If the problem persists, check the support links at
www.xerox.com/officeprinting/1235support.
Regards
Ashly
Feb 03, 2010 | Xerox Phaser 7300DN Laser Printer
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
207 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
