Yes if it's just Bluetooth you're trying to get to work by a new BT dongle. If wireless and BT are on the same card buy a new BT/wireless card This one Desktop 802 11ac Wifi Bluetooth 4 0 Dual band 1300M Wireless AC PCI... Works great. Try to stay away from Intel I had to replace two of them in the last six months. The link above uses Broadcom and works fantastic.
SOURCE: Cannot connect to my wireless network
you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window. Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
SOURCE: XP and Vista wireless LAN - computers don't see eachother
Here is an article that should help -- there may be a issue. based on this article the Vista Computer is connected to the internet or ISP's network with a wire.
Ad-hoc networking access point
SOURCE: wireless connection manager
remove all entries - run regedit delete all values from the adapter software and reinstall
SOURCE: General Networking question
lets see here, your NVIDIA thing is for your ethernet port in your computer.
the wireless PCI adapter, is well, a wireless adapter, its used to connect your wireless, and a 1394 Net Adaptor Connection is basically Win2k/XP's way of telling
you that you have a Firewire interface installed in your system.
so, if your going wireless, you dont need NVIDIA, and as your device manager shows that it has a red x on it, it shows that its disabled. as for everything else, i wouldent worry about it.
i think you have more than one connection in your settings of the same name
follow this step
1right click on network icon( connection in network)
2.device manager
3.select all wireless connection then
4. delete all the connection
close the window
now it will show the new connection
click pop up and click connect
enter yor pass key
NOTE: it will ask only if your securty is enable
