Question about Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer
Just had the sensor replaced on my maytag bravos 7.0 electric dryer, still the same problem, put in a load of jeans, sweatshirts, socks on normal time comes up as 40 min, after 40 min went to check on clothes, timer says 30 minutes, but clothes are dry? Sensor was just replaced this week, but still have the same problem, why?
Posted by rsyordy on
  • Brad Brown Nov 20, 2017
    Hi rsyordy, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Model number?
Neil Hadrich
    Habit-Forming:
    New Friend:
  • 7 Answers
Possibly a bad circuit board for the digital read out, when you start cycle the connections on the board are room temp. after progressing thru cycle for a period of time the connections warm up and cause circuit failure for the lighted read out. However all the other functions of operation are not affected. A quick look at the board itself would most likely indicate a problem by charred or discolored solder connections.
Posted on Nov 20, 2017
5 Related Answers
Anonymous
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
Prem Mulberry
  • 94 Answers
SOURCE: Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Posted on Oct 14, 2008
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Posted on Mar 18, 2010
Testimonial: "Thanks so much!"
Anonymous
  • 91 Answers
SOURCE: My maytag dryer does not dry clothes, it takes
Your dryer needs a new heating element. Any good Maytag repairman can put one in. If you are very handy you can do it yourself but if not it should not be an expensive job.
Posted on Mar 22, 2010
Anonymous
SOURCE: Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Posted on May 28, 2010
My bravos quiet series 300 will not turn on. what could be wrong
Check for power first must have all the juice one side of electric can be down. check door switch or replace Dryer electronic control board Part #: W10222206
Feb 20, 2015 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Thermal limiter maytag bravos dryer
a thermal limiter is a safety switch designed to keep a dryer from overheating, by either shutting off the heating element or the dryer itself if activated. They don't normally need replacing (unless you know your dryer overheated and activated it). If you have no heat in your dryer, chances are you have a bad heating element--the most common dryer problem
Jan 01, 2013 | GE DSXH47EGWW Electric Dryer
No matter what settin the dryer is on my clothes will only get a little warm, but won't dry. It won't heat up as usual.Had a load in there for a few hours yesterday. They are still damp. When dry clothes...
You vent could be the problem. Snow blocking the vent can cause the dryer heat to shut down rapidly. Make sure your vent is open to the outside. Get some windex and clean them moisture sensors inside the machine. If a film developes on them then moisture cannot be detected by the control. It might think the clothes are dry and shut her down. Maytag Bravos Dryer service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Bravo gas dryer takes too long todry clothes
Taking too long can be very difficult to troubleshoot because term is quite relative. A load of bed linens will dry much quicker than a load of jeans.
Check your dryer vent (usually outside) to see if a bird or critter has made a home. Then check your vent hose. Same thing, look for buildup of lint here. Check your filter as well. See if there has been any lint that has built up and fallen off the filter (look down in tube, holder, etc).
Since dryers use room air to circulate with, and then expel it outdoors, also make sure that there is adequate air flow to the dryer. Open a window in same room, if you can. If it improves, then your house is sealed up tight (and that's the problem).
Nov 02, 2009 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Maytag bravos dryer makes loud grating sound
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 01, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Logo
153 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
