Question about NetGear WGR614 Wireless Router
Dear sir i want to use my netgear wgr614 router as access point. please give me suggestion how can i do that
Posted by babaul_vac on
Bernie Buckman
    New Friend:
  • 114 Answers
Simply plug your modem into the yellow rj45 port in the back of the router with a standard Ethernet cable then plug a comp into one of the Ethernet ports and configure your wifi if necessary
Cheers
Posted on Jan 22, 2011
Steve Cowart
    Scholar:
  • 113 Answers
In Your web browser type in 192.168.0.1,it will ask you for a user name and password,user name is admin and password is password,once you enter the netgear setup utility find the section that ask you if you would like to use as an access point,check it,save changes-you will have to download the user manual on detailed step by step instructions from netgears website in order for it to work-i would download the user manual before you do anything at all and read first what has to be done-Good Luck-Access points are not easy to configure and must be connected via an ethernet cable when doing the initial setup-Have Fun
How do i add aditional routers to gain access to the network from a detached shop using wireless
Connect your addition routers to NetGear WGR614 Wireless Router port ,Use NetGear WGR614 Wireless Router as a switch ....
Check if it works
Thanks
Snadeep
Mar 08, 2011 | NetGear WGR614 Wireless Router
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
I ahve forgotten my forgotten netgear password on WGR614 router. Please advise Thanks Tony
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Dec 14, 2010 | NetGear WGR614 Router
Hello sir I am using Netgear WGR614-N150 Wireless Router and now i forgot that user name, password & passkey now what can i do pls guid me
This Utility program will help you locate few details of your network like :
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly
* Please rate this solution with Thumbs up
Nov 16, 2010 | NetGear WGR614 Wireless Router
Dear sir a client has a belkin N series router
Couldnt you just buy another wireless access point to extend the existing network?
E.g
http://www.netgear.co.uk/wireless_access_points_WPN802.php
Good luck :)
Jun 13, 2010 | Computers & Internet
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Mar 07, 2010 | NetGear WGR614 Wireless Router
My wgr614 v9 is slowing my internet !
well sir in this case please upgrade the firmware of the router to the latest one. This link will help you out in upgrading it:-
http://kb.netgear.com/app/answers/detail/a_id/11974
In this link you will have installation instructions just follow them and your router will give better performance.
Nov 24, 2009 | NetGear WGR614 Router
Netgear WGR614 Router won't configure to 64 bit Vista
If it's a new router read the book with it and it will tell you how to access the router via internet explorer. Something like this, on the address line of IE enter //192.168.0.1 and type enter. You will need the default login and password from the manual.
May 26, 2009 | NetGear WGR614 Router
Use Netgear WGR614 as an access point
Right, it won't work. The 614 doesn't have the software to make it into a BRIDGE or AP CLIENT. It can only be made into an Access Point, meaning it needs a wired connection INTO it.
A TP-Link http://www.tp-link.com/products/product_spe.asp?id=36 WA501G costs under $40 and gives you the ability to go from wireless to wired. It takes about 15 minutes to set up, and will plug into your DVR's ethernet port to extend your wireless network. It's programmed by setting the mode, AP, CLIENT, BRIDGE, etc. We use them in areas where we want to extend a wireless signal for distances like across parking lots, but it also will work across a room or two.
There are also wired ethernet extenders that use house wiring like the Netgear XE-102, about $80, that look like two wall transformers with ethernet jacks. You plug one into the router/switch and the other into the DVR.
Carl
Apr 21, 2009 | NetGear WGR614 Wireless Router
Firewall and Nat router configuration for BitComet
Has it ever worked? If not, run the disc that came with it. And what yellow light exactly do you speak of? Are the proper cables connected to the proper ports?
Mar 29, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
NetGear WGR614 Wireless Router Logo
48 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
