Question about Under Armour Zone Sunglasses
My Under Armour Zone sunglasses left hand side New Temple is broken. Do you have any replacement for this and if so how much will it cost. All it needs is replacement as I can easily unscrew and replaceit.
Posted by purna461 on
Jyackle5
  • 8,197 Answers
Sorry we do not sell parts. We try to help you fix your problem. Try the link below to get parts.
http://www.framesdirect.com/framesfp/Under_Armour-tdoimi/lb.html
Posted on Jan 22, 2011
Need a left temple for RB 3023 W 2963
contact the manufacturer we do not do sunglass parts here.
Sep 28, 2015 | Clothing Accessories
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
I need a replacement arm for rb2030 ps8 w2175
I'm in need of Ray Ban PS8 W2175 right temple as well.
Could anyone help, please?
(Or the whole frame, just to use the lens in good condition)
Feb 05, 2014 | Ray-Ban RB 2030 Sunglasses
How to remove unwanted scratches sunglasses? Brand
  • 1
    Put on a pair of plastic gloves and smear a thick layer of Armour Etch etching compound on your sunglass lenses---the tops and the bottoms of the lenses. Leave the Armour Etch on the sunglasses for five minutes and then rinse it off under the faucet with cold water. You can find Armour Etch at any craft store. It is designed to be a fast acting etching compound and works great for getting rid of scratches.
  • 2
    Spray lemon Pledge furniture polish directly on your lenses, both front and back. Rub it in with a rag. Wash the sunglasses with dish soap and water.
  • 3
    Spray the liquid Band-Aid on the sunglass lenses being careful to wipe off any excess with a paper towel. Let the liquid dry and then wear your sunglasses.
    Liquid Band-Aid is sold at pharmacies.
  • 4
    Apply BRASSO furniture polish to your lenses and rub it in for three minutes. This product tackles the really stubborn scratches. Wash your lenses off with soap and water.
  • 5
    Rub cigarette ashes in the scratches and then wash clean. You may have to do this more than once to completely get rid of the scratch.
  • Or
  • 1
    Use toothpaste. Apply a small amount of toothpaste on the lenses. Use a soft, cotton cloth to rub the toothpaste into the lenses. Use a small circular motion. The toothpaste will act as a filler and fill in the gap created by the scratch. Continue applying a circular motion for 10 seconds and rinse with lukewarm water. If the scratch is deep or stubborn, you might have to repeat the process.
  • 2
    Use baking soda to remove scratches on your sunglasses. Mix 1 part water to 2 parts baking soda to create a creamy paste. Use the cotton cloth to distribute the paste onto the scratched lens. Use a circular motion to rub the baking soda paste into the lens. Rinse with lukewarm water. More stubborn scratches warrant a second application.
  • 3
    Use windshield fluid. The windshield fluid will polish off the scratches. Apply a small amount of windshield fluid onto a cotton cloth. Polish the sunglasses with the cotton cloth for several seconds. This method is especially effective against smaller scratches but may not remove prominent blemishes.
  • 4
    Use vehicle wax. The lipids in the wax will fill in the scratches. Apply a small amount of vehicle wax onto the cotton cloth. Apply the cotton cloth into the offensive scratch. Keep using a circular motion until the scratch is removed. You may need to use several cloths, as the wax can adhere to the fabric, subsequently marring its performance.
  • 5
    Use an eyeglass polishing kit, which usually contain a soft cloth and polishing liquid. These kits are great to use on your glasses, telescopes and camera lenses, and can be purchased from your local drugstore or optometrist's office. The kit cost $10 to $20 in 2010.
  • Or
    Measure 1 teaspoon of baking soda into a bowl.
  • 2 Add enough water to the baking soda to make a thick paste. Mix the paste with your finger.
  • 3 Rub the paste over the scratches on the sunglasses with your finger. Rub in a circular motion.
  • 4 Rinse the paste off of the sunglasses with running water.
  • 5 Buff the sunglasses with a soft buffing cloth.
  • Apr 03, 2011 | Gucci GG 3036 Sunglasses
    How to replace the lenses for oakley spike
    I did the following... step by step, if you have any questions, please ask. - I placed the sunglasses perpendicular to me. One if the lenses will be close to you, while the other should be farther away.
    -I grabbed the farthest lens from your body with both hands. Placing your left had on the left side and your right and on the right side. One had is on the bottom of the lens, while the other is on the top of the lens. It does not matter which hand is on the bottom or top.
    -I grabbed the top and bottom of the frame, pulling away from the lens. At the same time I pushed with my fingers (that should be on the inside of the lenses) and pressed the lens out (on the lens closest to the nose pieces). You will hear a very faint "pop" when the lens clears the frame.
    -Then slide the lens out by grabbing the part that is out of the frame that is close to the nose piece
    -To put the new ones in, position the sunglasses the same way and put the replacement lens in the sunglasses, starting with the edge near the ear pieces.
    -Pull the top and bottom of the frame out and push the replacement lens into place.
    If you have any questions, please ask. If I can clarify anywhere, let me know.
    Good luck.
    And once you do this,could you please leave me feedback and vote on my answer?
    Thank you very much,
    Lori
    Mar 17, 2011 | Oakley Spike Sunglasses
    Could you please recommend me on a good sport sunglasses?
    Here are examples of some hight rated sunglasses: 1. Smith Sunglasses
    -Smith Sports Optics offers a huge slection of sunglasses specifically desiged for sports. In general you will find interchangeable lenses and maximum coverage without neglecting peripheral vision. The nosepads and temples have non-slip rubber so they stay in place during activity. 2.Oakley Sunglasses
    -Oakley makes sunglasses for every sport, weather condition, light condition and style. These lightweight, impact-resistant frames offers maximum durability, and complete customization. Some offer polarized lenses available, adjustable nose bridge, temples, and lenses for a completely customized fit. 3. UnderArmour Sunglasses
    Under Armour is a bit of a newcomer to the performance sports eyewear scene, but their good looks and functionality are taking off with athletes. All the Under Armour Performance lenses block 100% of UVA, UVB and UVC rays. They are designed to be lightweight, impact resistant and don't easily scratch.
    Under Armour Zone Sunglasses Logo
    722 people viewed this question
    Top Under Armour Clothing Accessories Experts
    Jim Pattison
    Tom Chichester
    Andrew Taylor
    Andrew Taylor
    Are you an Under Armour Clothing Accessory Expert? Answer questions, earn points and help others
