This type of camera downloads video with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 cameras have a USB connection which is used for stills ONLY.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Windows 7 compatibility- Sony say it is compatible, but "Windows 7 needs to be preinstalled at the factory" (meaning installed on the computer) rather than an Update to Vista or XP performed by the user. You must also use i.Link, not USB.
