Electrolux EOB5610 Ultrafan Electric Single Oven Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi The fan is this oven dosn't always work! Sometimes if you give it a gentle nudge it will start to spin other times it just wont spin at all & some times it works perfectly! any ideas on how to sort this?
Anonymous
Level 2:
  • Expert 174 Answers
  • Posted on Jan 22, 2011
Anonymous
Expert
Level 2:
Answers
174
Questions
Helped
126349
Points
483
You need to change the fan motor. These motors are not very powerful and wear in the bearing can cause this effect. oiling the bearings is only a tempory fix and you will eventually end up changing the motor.
It is making a loud noise as if it is catching onto something it comes and goes sometimes louder than first time it started
I'm guessing your problem is the fan in the oven. To fix: 1. with oven cold, remove back wall fan cover in oven. 2. remove fan. 3. clean and lubricate. 4. install fan. 5. install fan cover making sure fan is not touching. If cover does touch fan, gently bend cover away from fan and install.
May 15, 2016 • Ovens
The fan on my Whirlpool G2P62F electric oven is glowing red but not turning.
The fan is seized and is now working as a heater. It needs replaced. Try nudging the fan blades round it may loosen up.
Sep 03, 2014 • Ovens
2answers
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
The Inside of my oven wont get hot the light comes on but it doesnt get warm
If this is a fan over then check to see if the fan is spinning. If it is not spinning then the fan bearing has got tight. This is easily fixed by using a thin piece of wood, like a chop stick to give it a flick and get it moving.
Works a treat every time it happens to me.
If it's not a fan oven then you probably need to get the elements checked out.
2answers
Oven not getting hot but oven fan ligth working
If it is a fan assisted electric ovenn, and the fan is working o/k, then you need to replace the oven element, usually located at rear of oven compartment.
Please rate my solution.
Thanks.
My new neff oven b1524 dosn`t get hot the lights are on timer works but no heat??
Hi.
If it is a fan assisted oven, and the fan is working o/k, then you to replace the oven heater element.
Thanks.
4helpful
2answers
My oven is giving me an error of E6 F2, what does that mean
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control board. Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit). No error & fault code would appear. Pressing any keypad oven control did not work at all in this condition. When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed). It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet). The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol. I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector. VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power. So far, so good. After applying power, the "PF" with clock display always appears. I am able to set the clock and press "Start". Over functions normally. The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however
RATE THIS SOLUTION
RNJ VINOD KUMAR
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Neff Double oven 1410/1420
I think you got it david ..
check voltage to the motor at low and high.. if voltage is good.. them it must be the motor...let me know
Jul 07, 2008 • Ovens
Top Electrolux Ovens Experts
john h
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
