Question about Reddy R60A Utility Heater
The answer may not be that simple. It will be a process of ruling things out. First check fuel level, then check fuel filter, check to see if the photo sensor is dirty, then check the intake and exhaust filters. If these check out then you need to check pump pressure. Since I am not as familiar with this brand as I am with Dayton you will need to consult your operators manual or the manufacturer for pump pressure specs. If the pressure isn't high enough you will to adjust it to the currect pressure. You should find the problem prior to this point.
Posted on Jan 22, 2011
Dec 24, 2016 | Heating & Cooling
Jan 18, 2011 | Desa International Reddy Heater R40 40,000...
Jan 30, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Jan 23, 2010 | Reddy R60A Utility Heater
Jan 09, 2010 | Desa International Reddy Heater R40 40,000...
Oct 16, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Mar 22, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Dec 16, 2008 | Reddy Heater-30-55,000 BTU Variable
261 people viewed this question
