Question about Nintendo Wii Console
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Posted by llozano238 on
  • 6,259 Answers
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Posted on Jan 22, 2011
Anonymous
    New Friend:
Composite cables did the same for me. Black and white.
Got the component set at b.b. for $28. Problem solved.
Component cables are digital. Composite are analog. The Aquos is set up for digital, develops a picture from 3 visual inputs(component) rather than one(composite)
Posted on Apr 25, 2011
I previously had my wii on an older tv and it worked fine. I recently purchased a new tv (Sharp Quatron Aquos) and when I hooked up my wii and same cables to the tv, my screen is now a hazy black and white...
You are using composite cables(red,white,yellow) mine did the same thing. The aquos is all digital, wont read analog, which is what composite cables are.
They now make a component cable for the wii. I paid $28 at b.b.
Mar 12, 2011 | Nintendo Wii Console
I have hooked my wii up to a new samsung 42"
Make sure that you have switched the Wii to component video in the system setting menus. Once you have done that, you should have a color picture in 480p! Hope this helps!
Feb 27, 2011 | Nintendo Wii Console
I have had my wii for a while and it is black and we hooked it up to our flat screen Vizio and it is only in black and white but then when i hook it up to my older tv it is in color and i cant figure out...
Did you use the Component cables for the new tv? If you did, you need to go into the System Menu of the Wii, and change the output to Component 480p, and that should give you a color picture with a higher resolution. Hope this helps!
Feb 23, 2011 | Nintendo Wii Console
Hooked up the wii to a new emerson tv. no cable is attached to the tv. the wii is showing up in black and white only, how can I get color
no your wii is in pal (UK EDITION) while your tv is NTSC( USA EDITION) so not compactible. So try seeing if tv has setting of switchin to pal if not sorry this means you can only by and play uk games if you got the wii in the usa its the opposite for you.
Jan 12, 2011 | Nintendo Wii Console
Hooked up my Wii to a new TV, Now color is bad
I suspect you have it hooked up wrong check, Color to color, this is what can make it green, if not that then ensure your format is ok either PAL or NTSC, check.
Apr 02, 2010 | Nintendo Wii Console
TV went to black and white when hooking up the wii
You probably don't have something hooked up right or connected all the way. If you are using component video cables, make sure that all of the different plugs are plugged into the matching socket on your TV. Also, make sure you have your TV on the right channel (3 or 4) if that's how you have it setup.
Otherwise, you will want to look at the input settings on your TV and make sure you are receiving the correct input, and if you have your Wii plugged into a VCR instead of directly to your TV, try hooking it up directly to see if it works.
If that doesn't work, try using a different TV - especially if it's a TV you know works in color with a Wii. If it is still in black and white, you might need to take it back to the store and exchange it for a new one.
Nov 23, 2009 | Nintendo Wii Console
Plug in the wii system and everything comes in black and white
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
Jan 18, 2009 | Nintendo Wii Console
Screen losing color.. turning black and white
Your TV goes black & white, because your Wii could be NTSC or PAL which. If your Wii is PAL and your TV is NTSC then the TV will show a blac and white color. Since NTSC is for North America and PAL for Asia
Jan 13, 2008 | Nintendo Wii Console
Color picture for my wii
maybe the component cables are not working, try buying a new component cable.
Dec 26, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
