Question about Schlage Electronic Lock FE595 Plymouth or Camelot series
I lost the manual and i need to reprogram the codes
Posted by biker_piper on
Coaltowner
  • 963 Answers
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
There is a video on this page, showing how to change codes.
Posted on Mar 06, 2011
Reprogram liftmaster garage door opener
You will need the manual. If none, contact manufacturer for help.
Aug 09, 2013 | Building Materials
I have a problem with my Man Truck TGA 33.360, Its showing alot of error codes on dashboard EDC 00959-01, EDC 00960-01, EDC 00961-01, EDC 00962-01. What could be the problem?
I have an answer for you.The codes are coming from a lost Tachometer memory.Yoour Edc Control Unit and teh Tachometer are not correctly aligned.You need to have th Tachometer reprogrammed.It has lost memory
1.EDC:00959-01 >seconds-Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
3. EDC:00961-01>hour- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
4. EDC:00962-01>Day- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
5. EDC:00963-01>Month- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
6. EDC:00964-01>Year- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
Nov 15, 2012 | Bruder MAN TGA Container Service Truck
I have a universal remote and lost my manual, put new batteries in my remote...and now have to reprogram for my tv can you tell me the code for a sharp tv/vcr combination?
Here is a link to download the manual with instructions for programming the codes:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4220-manual.zip&area=other
Aug 18, 2011 | One For All URC4220 Remote Control
Need to reprogram the code but lost the manual
Hold down the 8 key until 2nd beep sounds. Enter the User Program Security Code. If this code has never been changed enter the default of 1+2+3+4+5+6. When the correct code has been entered the 1st 3 LED's will flash and the sounder will beep rapidly. Press the B/A key and then enter the User Code to be changed (1,2,3, etc.). Enter up to 4 numbers for the new code. Press the B/A key twice to exit the Program Mode. Hope this helps.
May 22, 2010 | Home Security
Changed battery and lost program cant find manual need reprogram 4 number code
changed the battery and lost the manual, put my code in and it worked , latter it started to beep and now it doesn't work... respond at all ....help thanks
Apr 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Lost owners manual need to reprogram the light
have you been to www.aerogarden.com. they have a troubleshooting area for the reprogramming of the lights.
Dec 30, 2009 | NRS AeroGarden 7-Pod Pro-100
Lost remote code book
found instruction manual on remote central site
Jun 25, 2009 | Directed 434MHZ Remote Control
Need programing codes lost the manual
After some research I have attached a clickable PDF file for you to check out. It is a for a Sanyo Remote Control. Give these codes a try. If it is not for your exact remote control, my best guess is that SANYO remotes all share the same codes. It's worth a try.
Hope this helps!- CBR2009
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Apr 14, 2009 | Sanyo 6450160929 Remote Control
I lost my manual for the One For All remote URC3021
google the maufacture and look on their website or try callign 1-800-remotes and askign if they sell manuals as well
Dec 19, 2008 | One For All URC-3021 Remote Control
Code for remote
need a code for a rca tv for my remote
Dec 07, 2008 | Philips Magnavox Learning Universal Remote
Schlage Electronic Lock FE595 Plymouth or Camelot series Logo
460 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
