Is the solution already found jet?
I have got the same problem.
I tryed to ad some rubber rings bud this didn't work.
The big problem I notise is the vibrating case.
(sorry for my english)
RDM5015S,Samsung AH31-00039B which I believe will be replaced by AH31-00056B, G5015M12DCS. The parts list quotes 0.12A rating on the RDM5015S fan which is marked 0.14A. I have some stripped down HT-BD2 head units.
The numbers you're looking at are the current drawn by the fan while it's running. The current drawn is a function of the fan speed. Your original fan was rated at 0.14 amps (or 140 milliamps or mA), so either of the ones you mention are close. The 60 mA fan you tried was either too slow, or because of the low current draw, the player's monitoring circuit thought the fan wasn't working. Since it's the closer match to the original part rating, use the 140 mA (0.14 A) fan. The little extra draw shouldn't make a difference to the player's monitoring circuit or power supply.
SOURCE: i need a 2x2 brushless fan model # rdm5015s dc 12
Perhaps try Google's Product Search?
It appears to be a fairly standard 50x50x15mm fan with a two pin type 2 connector. Try looking for a two pin 50mm fan with a thickness of less than or equal to 15mm.
A quick search I've done can be found here.
