Question about Polaroid PoGo Digital Photo Printer
SOURCE: can't find bluetooth
if its verizon you probably wont get it to work.
Posted on Jan 03, 2009
SOURCE: i can make a bluetooth connection anymore with my
go to the bluetooth utility on either your phone or your PC select the pogo printer and remove it. once you have done this. search for the printer again and use the pairing code 6-0-0-0 which will reconnect up correctly hope this helps
Posted on Oct 29, 2009
SOURCE: I cant print using my phone even tho it has
LG phones seem to send images with characters other than 0-9 and A-Z in the image filename. It looks like either the Pogo, or the LG phone bluetooth software doesn't accept this (I see "disconnected" if I try to print an image with a filename like that)
This solution "works" to the extent that renaming the file helps, though I don't know how to avoid these characters appearing in the filename of the photo in the first place :
http://www.fixya.com/support/t3651208-kp500_lg_cookie_compatible_pogo
Posted on Jan 06, 2010
SOURCE: print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access
Piont: My Home Wifi (kaba)
Host : ip address of you
printer
user : Blank ( tried my windows username,no
use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Posted on May 20, 2010
SOURCE: I successfully paired my Pogo with my Samsung
I had the same problem with my samsung fascinate. I called Polaroid and they told me the phone is not supported and they could not help. I tried something different and it worked!!!! I downloaded the polaroid PoGo app in the android marketplace(free app). Print your pictures from the Gallary thru the app. It works fine. All my pics print and there is no more problem. Give it a try
lloyd
Posted on Dec 17, 2010
Oct 28, 2015 | Samsung Intensity II U460 Verizon
on Oct 26, 2010 | Samsung SCH-U450 Cell Phone
on Oct 16, 2010 | Samsung SCH-U450 Cell Phone
Jun 26, 2012 | Boost Mobile Samsung Replenish Mobile...
Jun 23, 2012 | Samsung Intensity
May 30, 2012 | Samsung Intensity 2 U460 + Screen...
Aug 12, 2011 | Samsung Cell Phones
Dec 07, 2010 | Samsung WEP250 AWEP250JBECXAR WEP 250...
Feb 09, 2010 | Samsung SPH-M800 Cell Phone
Sep 27, 2009 | Cell Phones
51 people viewed this question
